Datasheet ADP5020 (Analog Devices) - 5
DescriptionPower Management Unit for Imaging Modules
Pages / Page28 / 5 — ADP5020. SWITCHING SPECIFICATIONS. Table 2. Parameter Symbol. Conditions …
ADP5020. SWITCHING SPECIFICATIONS. Table 2. Parameter Symbol. Conditions Min. Typ. Max. Unit
ADP5020 SWITCHING SPECIFICATIONS Table 2 Parameter Symbol Conditions Min Typ Max Unit
link to page 28 link to page 28 link to page 28 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 14
ADP5020 SWITCHING SPECIFICATIONS Table 2. Parameter Symbol Conditions Min Typ Max Unit
SWITCHING FREQUENCY CH1 fSW1 Sync disabled 2.5 3 3.6 MHz CH2 fSW2 Sync disabled 2.5 3 3.6 MHz SYNC CLOCK DIVIDER RATIO RATIODIV SYNC_9P6 = 1 3 RATIODIV SYNC_19P2 = 1 6 SYNC CHARACTERISTICS Frequency Range fSYNC1 9.6 MHz fSYNC2 19.2 MHz Frequency Duty Cycle fSYNCDUTY 40 50 60 % Signal DC Coupling Level Low Level Input Voltage VIL 0.3 × VDD_IO V High Level Input Voltage VIH 0.7 × VDD_IO V DC Coupling VSYNC 0 VDD_IO V AC Coupling Level VCAC-PP Sine wave, peak-to-peak 0.5 1.0 VDD_IO V AC Coupling Capacitor 10 nF Input Current ISYNC SYNC_9P6 = 1, or SYNC_19P2 = 1 50 μA
DC-TO-DC CONVERSION SPECIFICATIONS, BUCK 1 REGULATOR Table 3. Parameter Symbol Conditions Min Typ Max Unit
OUTPUT VOLTAGE Range1 VOUT1 3-bit range 2.5 3.7 V Initial Accuracy T 2 A = 25°C, VDD1 , VOUT1 = 3.3 V, ILOAD = 20 mA −1 +1 % Total Accuracy V 3 DD1 , ILOAD = 50 mA to 600 mA −5 +4 % VOUT1 REGULATION Load Regulation ILOAD = 20 mA to 600 mA 0.2 % Line Regulation V 2, 3 DDA = 1.8 V, VDD1 0.15 % CURRENT Maximum Output Current I 3 BK1MAX VDD1 , VOUT1 = 2.5 V to 3.7 V 600 mA Quiescent Current IQBK1 ILOAD = 0 mA 4 6 mA POWER Low-Side Power nMOSFET RDSON1 ID = 400 mA 175 250 mΩ High-Side Power pMOSFET RDSON1 ID = 400 mA 250 400 mΩ SWITCH CURRENT LIMIT ICL1 0.8 1.2 1.6 A MINIMUM ON TIME tMIN1 55 ns MAXIMUM DUTY CYCLE DMAX1 88 95 % SOFT START TIME tSS1 1.4 ms COUT DISCHARGE SWITCH ON RESISTANCE RDIS1 0.7 1 1.3 kΩ 1 See Tabl (t e 13 he BUCK1_VSEL register, Address 0x01) for details. 2 VDD1 = 3.1 V to 5.5 V, ILOAD is less than 200 mA. For tight regulation, the supply voltage must be 0.6 V higher than the output voltage. 3 VDD1 = 3.7 V to 5.5 V, ILOAD is more than 200 mA. For tight regulation, the supply voltage must be 1.2 V higher than the output voltage. Rev. 0 | Page 5 of 28 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATIONS CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS SWITCHING SPECIFICATIONS DC-TO-DC CONVERSION SPECIFICATIONS, BUCK 1 REGULATOR DC-TO-DC CONVERSION SPECIFICATIONS, BUCK 2 REGULATOR VOUT3 SPECIFICATIONS, LOW DROPOUT (LDO) REGULATOR I2C TIMING SPECIFICATIONS Timing Diagram ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Thermal Data ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION CIRCUIT OPERATION INTERNAL COMPENSATION CURRENT LIMITING AND SHORT-CIRCUIT PROTECTION SYNCHRONIZATION I2C INTERFACE UNDERVOLTAGE LOCKOUT THERMAL SHUTDOWN CONTROL REGISTERS DEVICE ADDRESS REGISTER MAP REGISTER DESCRIPTIONS User Accessible Registers POWER-UP/POWER-DOWN SEQUENCE SEQUENCER DEFAULT POWER-ON SEQUENCE WITH EN PIN Activation Waveforms POWER-ON SEQUENCE USING THE I2C INTERFACE POWER-UP/POWER-DOWN STATE FLOW APPLICATIONS INFORMATION POWER GOOD STATUS XSHTDN LOGIC COMPONENTS SELECTION Buck Inductor Input Capacitor Selection Output Capacitor Selection LDO INPUT FILTER LAYOUT RECOMMENDATIONS APPLICATIONS SCHEMATIC PCB BOARD LAYOUT RECOMMENDATIONS EXTERNAL COMPONENT LIST OUTLINE DIMENSIONS ORDERING GUIDE
