Datasheet LTC3548-1 (Analog Devices) - 9
DescriptionDual Synchronous, Fixed Output 2.25MHz Step-Down DC/DC Regulator
Pages / Page16 / 9 — APPLICATIONS INFORMATION. Output Capacitor (C. OUT) Selection. Ceramic …
File Format / SizePDF / 332 Kb
APPLICATIONS INFORMATION. Output Capacitor (C. OUT) Selection. Ceramic Input and Output Capacitors
APPLICATIONS INFORMATION Output Capacitor (C OUT) Selection Ceramic Input and Output Capacitors
LTC3548-1
where the maximum average output current IMAX equals of any aluminum electrolytic at a somewhat higher price. the peak current minus half the peak-to-peak ripple cur- Special polymer capacitors, such as Sanyo POSCAP, rent, IMAX = ILIM – ΔIL/2. Panasonic Special Polymer (SP), and Kemet A700, of- fer very low ESR, but have a lower capacitance density This formula has a maximum at VIN = 2VOUT, where IRMS than other types. Tantalum capacitors have the highest = IOUT/2. This simple worst-case is commonly used to capacitance density, but they have a larger ESR and it design because even signifi cant deviations do not offer is critical that the capacitors are surge tested for use in much relief. Note that capacitor manufacturer’s ripple cur- switching power supplies. An excellent choice is the AVX rent ratings are often based on only 2000 hours lifetime. TPS series of surface mount tantalums, available in case This makes it advisable to further derate the capacitor, heights ranging from 2mm to 4mm. Aluminum electrolytic or choose a capacitor rated at a higher temperature than capacitors have a signifi cantly larger ESR, and are often required. Several capacitors may also be paralleled to meet used in extremely cost-sensitive applications provided that the size or height requirements of the design. An additional consideration is given to ripple current ratings and long 0.1μF to 1μF ceramic capacitor is also recommended on term reliability. Ceramic capacitors have the lowest ESR VIN for high frequency decoupling, when not using an all and cost, but also have the lowest capacitance density, ceramic capacitor solution. a high voltage and temperature coeffi cient, and exhibit
Output Capacitor (C
audible piezoelectric effects. In addition, the high Q of
OUT) Selection
ceramic capacitors along with trace inductance can lead The selection of COUT is driven by the required ESR to to signifi cant ringing. minimize voltage ripple and load step transients. Typically, once the ESR requirement is satisfi ed, the capacitance In most cases, 0.1μF to 1μF of ceramic capacitors should is adequate for fi ltering. The output ripple (ΔV also be placed close to the LTC3548-1 in parallel with the OUT) is determined by: main capacitors for high frequency decoupling. V
OUT IL ESR + 1 8f O COUT Higher value, lower cost ceramic capacitors are now be- where f coming available in smaller case sizes. These are tempting O = operating frequency, COUT = output capacitance and ΔI for switching regulator use because of their very low ESR. L = ripple current in the inductor. The output ripple is highest at maximum input voltage since ΔI Unfortunately, the ESR is so low that it can cause loop L increases with input voltage. With ΔI stability problems. Solid tantalum capacitor ESR generates L = 0.3 • IOUT(MAX) the output ripple will be less than 100mV at maximum V a loop “zero” at 5kHz to 50kHz that is instrumental in giving IN and f acceptable loop phase margin. Ceramic capacitors remain O = 2.25MHz with: capacitive to beyond 300kHz and usually resonate with their ESRCOUT < 150mΩ ESL before ESR becomes effective. Also, ceramic caps are Once the ESR requirements for C prone to temperature effects which requires the designer OUT have been met, the RMS current rating generally far exceeds the I to check loop stability over the operating temperature RIPPLE(P-P) requirement, except for an all ceramic solution. range. To minimize their large temperature and voltage coeffi cients, only X5R or X7R ceramic capacitors should In surface mount applications, multiple capacitors may be used. A good selection of ceramic capacitors is available have to be paralleled to meet the capacitance, ESR or from Taiyo Yuden, AVX, Kemet, TDK and Murata. RMS current handling requirement of the application. Aluminum electrolytic, special polymer, ceramic and dry Great care must be taken when using only ceramic input tantalum capacitors are all available in surface mount and output capacitors. When a ceramic capacitor is used packages. The OS-CON semiconductor dielectric capacitor at the input and the power is being supplied through long available from Sanyo has the lowest ESR (size) product wires, such as from a wall adapter, a load step at the output 35481fc 9
