Datasheet LT1941 (Analog Devices) - 3
Description | Triple Monolithic Switching Regulator |
Pages / Page | 24 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply … |
File Format / Size | PDF / 237 Kb |
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating temperature
LT1941
The ELECTRICAL CHARACTERISTICS
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN, VBIAS1, VBIAS2 = 5V, VBOOST1, VBOOST2 = 8V, unless otherwise noted. (Note 2) PARAMETER CONDITIONS MIN TYP MAX UNITS
Switching Phase SW1 to SW2 150 180 210 Deg SW1 to SW3 –30 0 30 Deg Foldback Frequency VFB = 0V 200 kHz RUN/SS Current 1 2 3 μA RUN/SS Threshold 0.4 0.6 V 5GOOD Threshold VIN Rising 4.5 V 5GOOD Voltage Output Low I5GOOD = 125μA, VIN = 4V 0.2 0.4 V 5GOOD Leakage V5GOOD = 2V 10 400 nA 12GOOD Threshold VIN Rising 10.8 V 12GOOD Voltage Output Low I12GOOD = 125μA 0.2 0.4 V 12GOOD Leakage V12GOOD = 2V, VIN = 12V 10 400 nA PGOOD Voltage Output Low IPGOOD = 200μA 0.2 0.4 V PGOOD Pin Leakage VPGOOD = 2V 10 400 nA
3A Step-Down
FB1 Voltage 618 628 638 mV l 613 638 mV FB1 Pin Bias Current l 50 500 nA PGOOD1 Threshold Offset VFB Rising 54 mV Frequency Shift Threshold on FB1 0.35 V Error Amplifi er Transconductance 1700 μMhos Error Amplifi er Voltage Gain 500 V/V VC Switching Threshold 0.9 V VC1 to Switch Current Gain 5 A/V Switch 1 Current Limit (Note 3) VIN = 12V, VBOOST1, VBOOST2 = 15V l 3 4.3 6 A Switch 1 VCESAT (Note 7) ISW = 2.5A 400 600 mV BOOST1 Pin Current ISW = 2.5A 40 60 mA Switch 1 Leakage Current 0.01 10 μA Minimum Boost Voltage Above Switch (Note 4) 1.8 2.5 V Maximum Duty Cycle l 78 88 %
2A Step-Down
FB2 Voltage 618 628 638 mV l 613 638 mV FB2 Pin Bias Current l 50 500 nA PGOOD2 Threshold Offset VFB Rising 54 mV Frequency Shift Threshold on FB2 0.35 V Error Amplifi er Transconductance 1700 μMhos Error Amplifi er Voltage Gain 500 V/V VC Switching Threshold 0.9 V VC2 to Switch Current Gain 3.6 A/V Switch 2 Current Limit (Note 3) VIN = 12V, VBOOST1, VBOOST2 = 15V l 2 2.9 4.1 A Switch 2 VCESAT (Note 7) ISW = 1.5A 450 600 mV BOOST2 Pin Current ISW = 1.5A 26 40 mA 1941fb 3
