Datasheet LTC1877 (Analog Devices) - 2
DescriptionHigh Efficiency Monolithic Synchronous Step-Down Regulator
Pages / Page18 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 246 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC1877
Input Supply Voltage (VIN) ..–0.3V to 11V TOP VIEW ITH, PLL LPF Voltage ... –0.3V to 2.7V RUN 1 8 PLL LPF RUN, V I 2 TH 7 SYNC/MODE FB Voltages .. –0.3V to VIN VFB 3 6 VIN SYNC/MODE Voltage .. –0.3V to VIN GND 4 5 SW SW Voltage ... –0.3V to (VIN + 0.3V) MS8 PACKAGE 8-LEAD PLASTIC MSOP P-Channel MOSFET Source Current (DC) .. 800mA TJMAX = 125°C, θJA = 150°C/W N-Channel MOSFET Sink Current (DC) .. 800mA Peak SW Sink and Source Current .. 1.5A Operating Temperature Range (Note 2) ... –40°C to 85°C Junction Temperature (Note 3) .. 125°C Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) ... 300°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC1877EMS8#PBF LTC1877EMS8#TRPBF LTLU 8-Lead Plastic MSOP –40°C to 85°C LTC1877IMS8#PBF LTC1877IMS8#TRPBF LTLV 8-Lead Plastic MSOP –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 5V unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IVFB Feedback Current (Note 4) l 4 30 nA VFB Regulated Output Voltage (Note 4) 0°C ≤ TA ≤ 85°C 0.784 0.8 0.816 V (Note 4) –40°C ≤ TA ≤ 85°C l 0.74 0.8 0.84 V ΔVOVL Output Overvoltage Lockout ΔVOVL = VOVL – VFB l 20 50 110 mV ΔVFB Reference Voltage Line Regulation VIN = 2.65V to 10V (Note 4) 0.05 0.15 %/V VLOADREG Output Voltage Load Regulation Measured in Servo Loop; VITH = 0.9V to 1.2V l 0.1 0.5 % Measured in Servo Loop; VITH = 1.6V to 1.2V l –0.1 –0.5 % VIN Input Voltage Range l 2.65 10 V IQ Input DC Bias Current (Note 5) Pulse-Skipping Mode 2.65V < VIN < 10V, VSYNC/MODE = 0V, IOUT = 0A 230 350 μA Burst Mode Operation VSYNC/MODE = VIN, IOUT = 0A 10 15 μA Shutdown VRUN = 0V, VIN = 10V 0 1 μA fOSC Oscillator Frequency VFB = 0.8V 495 550 605 kHz VFB = 0V 80 kHz fSYNC SYNC Capture Range 400 700 kHz 1877fb 2
