Datasheet LTC3802 (Analog Devices) - 2
Description | Dual 550kHz Synchronous 2-Phase DC/DC Controller with Programmable Up/Down Tracking |
Pages / Page | 28 / 2 — ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL … |
File Format / Size | PDF / 359 Kb |
ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHARACTERISTICS The
LTC3802
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Supply Voltage Extended Commercial VCC, PVCC ... 7V Operating Temperature Range (Note 2) .. –40°C to 85°C BOOSTn .. 37V Storage Temperature Range BOOSTn – SWn .. 7V LTC3802EGN ... – 65°C to 150°C SWn .. –1V to 30V LTC3802EUH ... – 65°C to 125°C Input Voltage Lead Temperature (Soldering, 10 sec) VINFF .. 30V LTC3802EGN Only ... 300°C FBn, CMPINn, FBT, PLLIN, FCB, RUN/SS, PGOOD, PLLLPF, PHASEMD, EXTREF, IMAXn .. –0.3V to VCC + 0.3V
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART TOP VIEW ORDER PART PV 1 28 CC BG2 NUMBER NUMBER CC BG1 2 27 BOOST2 TG1 BOOST1 BG1 PV BG2 BOOST2 TG2 SW2 LTC3802EGN 32 31 30 29 28 27 26 25 LTC3802EUH BOOST1 3 26 TG2 SW1 1 24 PGND TG1 4 25 SW2 PGND 2 23 PGND SW1 5 24 PLLIN PGND 3 22 PLLIN PGND 6 23 PLLLPF IMAX1 4 21 PLLLPF I 7 22 MAX1 IMAX2 33 FBT 5 20 IMAX2 FBT 8 21 CMPIN2 CMPIN1 6 19 CMPIN2 CMPIN1 9 20 VCC COMP1 7 18 VCC UH PART COMP1 10 19 COMP2 FB1 8 17 COMP2 MARKING FB1 11 18 FB2 9 10 11 12 13 14 15 16 SGND 12 17 PHASEMD 3802 FCB INFF FB2 FCB 13 16 VINFF SGND V EXTREF RUN/SS PGOOD RUN/SS 14 15 PGOOD PHASEMD UH PACKAGE GN PACKAGE 32-LEAD (5mm × 5mm) PLASTIC QFN 28-LEAD PLASTIC SSOP TJMAX = 125°C, θJA = 34°C/W TJMAX = 125°C, θJA = 110°C/W EXPOSED PAD (PIN 33) IS GND MUST BE SOLDERED TO PCB Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full operating temperature range. (Note 3) VCC = PVCC = BOOST = 5V, unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VCC VCC Supply Voltage ● 3 5 6 V PVCC PVCC Supply Voltage (Note 4) ● 5 6 V BVCC BOOST Pin Voltage VBOOST – VSW (Note 4) ● 5 6 V VUVLO Positive Undervoltage Lockout Measured at VCC 2.2 2.5 2.8 V Measured at VINFF 2.2 2.5 2.8 V IVCC VCC Supply Current VFB = VCOMP ● 6.5 9 mA VRUN/SS = 0V, PLLIN Floating ● 100 150 µA 3802f 2
