Datasheet LTC3707-SYNC (Analog Devices) - 2
DescriptionHigh Efficiency, 2-Phase Synchronous Step-Down Switching Regulator
Pages / Page32 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 404 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC3707-SYNC
Input Supply Voltage (V TOP VIEW IN) ... 30V to –0.3V Top Side Driver Voltages RUN/SS1 1 28 PGOOD (BOOST1, BOOST2) ... 36V to –0.3V SENSE1+ 2 27 TG1 SENSE1– 3 SW1 Switch Voltage (SW1, SW2) ... 30V to –5V 26 V 4 25 BOOST1 INTV OSENSE1 CC, EXTVCC, RUN/SS1, RUN/SS2, (BOOST1-SW1), PLLFLTR 5 24 VIN (BOOST2-SW2), PGOOD .. 7V to –0.3V PLLIN 6 23 BG1 SENSE1+, SENSE2+, SENSE1–, FCB 7 22 EXTVCC SENSE2– Voltages ...(1.1)INTVCC to –0.3V I 8 21 TH1 INTVCC PLLIN, PLLFLTR, FCB, Voltage ... INTVCC to –0.3V SGND 9 20 PGND ITH1, ITH2, VOSENSE1, VOSENSE2 Voltages ... 2.7V to –0.3V 3.3V 10 19 OUT BG2 Peak Output Current <10μs (TG1, TG2, BG1, BG2) ...3A I 11 18 TH2 BOOST2 INTVCC Peak Output Current ... 40mA V 12 17 OSENSE2 SW2 Operating Temperature Range (Note 2).. –40°C to 85°C SENSE2– 13 16 TG2 Junction Temperature (Note 3) ... 125°C SENSE2+ 14 15 RUN/SS2 Storage Temperature Range ... –65°C to 150°C GN PACKAGE Lead Temperature (Soldering, 10 sec) .. 300°C 28-LEAD PLASTIC SSOP TJMAX = 125°C, θJA = 80°C/W
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3707EGN-SYNC#PBF LTC3707EGN-SYNC#TRPBF LTC3707EGN-SYNC 28-Lead Plastic SSOP –40°C to 85°C LTC3707IGN-SYNC#PBF LTC3707IGN-SYNC#TRPBF LTC3707IGN-SYNC 28-Lead Plastic SSOP –40°C to 85°C
LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3707EGN-SYNC LTC3707EGN-SYNC#TR LTC3707EGN-SYNC 28-Lead Plastic SSOP –40°C to 85°C LTC3707IGN-SYNC LTC3707IGN-SYNC#TR LTC3707IGN-SYNC 28-Lead Plastic SSOP –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 15V, VRUN/SS1, 2 = 5V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loops
VOSENSE1, 2 Regulated Feedback Voltage (Note 4); ITH1, 2 Voltage = 1.2V l 0.788 0.800 0.812 V IVOSENSE1, 2 Feedback Current (Note 4) –5 –50 nA VREFLNREG Reference Voltage Line Regulation VIN = 3.6V to 30V (Note 4) 0.002 0.02 %/V VLOADREG Output Voltage Load Regulation (Note 4) Measured in Servo Loop; ΔITH Voltage = 1.2V to 0.7V l 0.1 0.5 % Measured in Servo Loop; ΔITH Voltage = 1.2V to 2.0V l –0.1 –0.5 % gm1, 2 Transconductance Amplifi er gm ITH1, 2 = 1.2V; Sink/Source 5μA; (Note 4) 1.3 mmho 3707sfa 2
