Datasheet LTC2333-16 (Analog Devices) - 9
Description | Buffered 8-Channel, 16-Bit, 800ksps Differential ±10.24V ADC with 30VP-P Common Mode Range |
Pages / Page | 40 / 9 — Typical perForMance characTerisTics. TA = 25°C, VCC = +15V, VEE = –15V, … |
File Format / Size | PDF / 2.2 Mb |
Typical perForMance characTerisTics. TA = 25°C, VCC = +15V, VEE = –15V, VDD = 5V,
![Typical perForMance characTerisTics TA = 25°C, VCC = +15V, VEE = –15V, VDD = 5V,](https://www.rlocman.ru/datasheet/img.php?di=152315&p=8)
LTC2333-16
Typical perForMance characTerisTics TA = 25°C, VCC = +15V, VEE = –15V, VDD = 5V, OVDD = 2.5V, Internal Reference and Buffer (VREFBUF = 4.096V), fSMPL = 800ksps, unless otherwise noted. Integral Nonlinearity Integral Nonlinearity Differential Nonlinearity vs Output Code and Channel vs Output Code and Channel vs Output Code and Range
1.00 1.00 0.5 ±10.24V RANGE ±10.24V RANGE ALL RANGES TRUE BIPOLAR DRIVE (IN– = 0V) 0.75 FULLY DIFFERENTIAL DRIVE (IN– = –IN+) 0.75 0.4 ALL CHANNELS ALL CHANNELS ALL CHANNELS 0.3 0.50 0.50 0.2 0.25 0.25 0.1 0 0 0.0 –0.25 –0.25 –0.1 INL ERROR (LSB) INL ERROR (LSB) DNL ERROR (LSB) –0.2 –0.50 –0.50 –0.3 –0.75 –0.75 –0.4 –1.00 –1.00 –0.5 –32768 –16384 0 16384 32768 –32768 –16384 0 16384 32768 0 16384 32768 49152 65536 OUTPUT CODE OUTPUT CODE OUTPUT CODE 233316 G01 233316 G02 233316 G03
Integral Nonlinearity Integral Nonlinearity Integral Nonlinearity vs Output Code and Range vs Output Code and Range vs Output Code and Range
1.00 1.00 1.00 TRUE BIPOLAR DRIVE (IN– = 0V) FULLY DIFFERENTIAL DRIVE (IN– = –IN+) UNIPOLAR DRIVE (IN– = 0V) ONE CHANNEL 0.75 ONE CHANNEL 0.75 ONE CHANNEL 0.75 0.50 ±10.24V AND ±10V 0.50 0.50 RANGES 0.25 0.25 ±10.24V AND ±10V 0.25 0V TO 5.12V RANGE RANGES 0 0 0 –0.25 ±5.12V AND ±5V –0.25 –0.25 INL ERROR (LSB) INL ERROR (LSB) ±5.12V AND ±5V RANGES INL ERROR (LSB) –0.50 RANGES –0.50 –0.50 0V TO 10.24V AND 0V TO 10V RANGES –0.75 –0.75 –0.75 –1.00 –1.00 –1.00 –32768 –16384 0 16384 32768 –32768 –16384 0 16384 32768 0 16384 32768 49152 65536 OUTPUT CODE OUTPUT CODE OUTPUT CODE 233316 G04 233316 G05 233316 G06
Integral Nonlinearity vs Output Code DC Histogram (Zero-Scale) DC Histogram (Near Full-Scale)
1.00 200000 200000 ±10.24V RANGE ±10.24V RANGE ±10.24V RANGE 0.75 180000 180000 160000 160000 0.50 TRUE BIPOLAR DRIVE (IN– = 0V) 140000 140000 0.25 120000 120000 0 100000 100000 COUNTS COUNTS –0.25 80000 80000 INL ERROR (LSB) 60000 60000 –0.50 ARBITRARY DRIVE 40000 40000 IN+/IN– COMMON MODE –0.75 SWEPT –10.24V to 10.24V 20000 20000 –1.00 0 0 –32768 –16384 0 16384 32768 –4 –3 –2 –1 0 1 2 3 32759 32761 32763 32765 32767 OUTPUT CODE CODE CODE 233316 G07 233316 G08 233316 G09 233316f For more information www.linear.com/LTC2333-16 9 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Reference Buffer Characteristics Digital Inputs and Digital Outputs Power Requirements ADC Timing Characteristics Typical Performance Characteristics Pin Functions Configuration Tables Functional Block Diagram Timing Diagram Applications Information Board Layout Package Description Typical Application Related Parts
