Datasheet ADM3053 (Analog Devices) - 3
DescriptionSignal and Power Isolated CAN Transceiver with Integrated Isolated DC-to-DC Converter
Pages / Page18 / 3 — Data Sheet. ADM3053. SPECIFICATIONS. Table 1. Parameter. Symbol. Min. …
RevisionE
File Format / SizePDF / 527 Kb
Data Sheet. ADM3053. SPECIFICATIONS. Table 1. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
Data Sheet ADM3053 SPECIFICATIONS Table 1 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 4
All voltages are relative to their respective grounds; 4.5 V ≤ VCC ≤ 5.5 V; 3.0 V ≤ VIO ≤ 5.5 V. All minimum/maximum specifications apply over the entire recommended operation range, unless otherwise noted. All typical specifications are at TA = 25°C, VCC = 5 V, and VIO = 5 V unless otherwise noted.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
SUPPLY CURRENT Logic Side isoPower Current Recessive State ICC 29 36 mA RL = 60 Ω, RS = low, see Figure 25 Dominant State ICC 195 260 mA RL = 60 Ω, RS = low, see Figure 25 TxD/RxD Data Rate 1 Mbps ICC 139 200 mA RL = 60 Ω, RS = low, see Figure 25 Logic Side iCoupler Current TxD/RxD Data Rate 1 Mbps IIO 1.6 2.5 mA DRIVER Logic Inputs Input Voltage High VIH 0.7 VIO V Output recessive Input Voltage Low VIL 0.25 VIO V Output dominant CMOS Logic Input Currents IIH, IIL 500 µA TxD Differential Outputs Recessive Bus Voltage VCANL, VCANH 2.0 3.0 V TxD = high, RL = ∞, see Figure 22 CANH Output Voltage VCANH 2.75 4.5 V TxD = low, see Figure 22 CANL Output Voltage VCANL 0.5 2.0 V TxD = low, see Figure 22 Differential Output Voltage VOD 1.5 3.0 V TxD = low, RL = 45 Ω, see Figure 22 VOD −500 +50 mV TxD = high, RL = ∞, see Figure 22 Short-Circuit Current, CANH ISCCANH −200 mA VCANH = −5 V −100 mA VCANH = −36 V Short-Circuit Current, CANL ISCCANL 200 mA VCANL = 36 V RECEIVER Differential Inputs Differential Input Voltage Recessive VIDR −1.0 +0.5 V −7 V < VCANL, VCANH < +12 V, see Figure 23, CL = 15 pF Differential Input Voltage Dominant VIDD 0.9 5.0 V −7 V < VCANL, VCANH < +12 V, see Figure 23, CL = 15 pF Input Voltage Hysteresis VHYS 150 mV See Figure 3 CANH, CANL Input Resistance RIN 5 25 kΩ Differential Input Resistance RDIFF 20 100 kΩ Logic Outputs Output Low Voltage VOL 0.2 0.4 V IOUT = 1.5 mA Output High Voltage VOH VIO − 0.3 VIO − 0.2 V IOUT = −1.5 mA Short Circuit Current IOS 7 85 mA VOUT = GND1 or VIO VOLTAGE REFERENCE Reference Output Voltage VREF 2.025 3.025 V |IREF = 50 µA| COMMON-MODE TRANSIENT IMMUNITY1 25 kV/µs VCM = 1 kV, transient magnitude = 800 V SLOPE CONTROL Current for Slope Control Mode ISLOPE −10 −200 µA Slope Control Mode Voltage VSLOPE 1.8 3.3 V 1 CM is the maximum common-mode voltage slew rate that can be sustained while maintaining specification compliant operation. VCM is the common-mode potential difference between the logic and bus sides. The transient magnitude is the range over which the common mode is slewed. The common-mode voltage slew rates apply to both rising and falling common-mode voltage edges. Rev. E | Page 3 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS SWITCHING CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS VDE 0884 INSULATION CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS CIRCUIT DESCRIPTION CAN TRANSCEIVER OPERATION SIGNAL ISOLATION POWER ISOLATION TRUTH TABLES THERMAL SHUTDOWN DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY APPLICATIONS INFORMATION PCB LAYOUT EMI CONSIDERATIONS RS PIN INSULATION LIFETIME TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
