link to page 16 Data SheetADM3053ABSOLUTE MAXIMUM RATINGS TA = 25°C, unless otherwise noted. All voltages are relative to Table 7. Maximum Continuous Working Voltage1 their respective ground. ParameterMax UnitReference StandardTable 6. AC Voltage ParameterRating Bipolar Waveform 424 V peak 50 year minimum lifetime VCC −0.5 V to +6 V Unipolar Waveform VIO −0.5 V to +6 V Basic Insulation 1074 V peak Maximum approved Digital Input Voltage, TxD −0.5 V to VIO + 0.5 V working voltage per Digital Output Voltage, RxD −0.5 V to VIO + 0.5 V IEC60950-1 CANH, CANL −36 V to +36 V Reinforced Insulation 537 V peak Maximum approved VREF −0.5 V to +6 V working voltage per R IEC60950-1 S −0.5 V to +6 V Operating Temperature Range −40°C to +85°C DC Voltage Storage Temperature Range −55°C to +150°C Basic Insulation 1074 V peak Maximum approved ESD (Human Body Model) 3 kV working voltage per IEC60950-1 Lead Temperature Reinforced Insulation 537 V peak Maximum approved Soldering (10 sec) 300°C working voltage per Vapor Phase (60 sec) 215°C IEC60950-1 Infrared (15 sec) 220°C θ 1 Refers to continuous voltage magnitude imposed across the isolation JA Thermal Impedance 53°C/W barrier. See the Insulation Lifetime section for more details. TJ Junction Temperature 150°C ESD CAUTION Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. E | Page 7 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS SWITCHING CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS VDE 0884 INSULATION CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS CIRCUIT DESCRIPTION CAN TRANSCEIVER OPERATION SIGNAL ISOLATION POWER ISOLATION TRUTH TABLES THERMAL SHUTDOWN DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY APPLICATIONS INFORMATION PCB LAYOUT EMI CONSIDERATIONS RS PIN INSULATION LIFETIME TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
