Datasheet ADM3053 (Analog Devices) - 8
DescriptionSignal and Power Isolated CAN Transceiver with Integrated Isolated DC-to-DC Converter
Pages / Page18 / 8 — ADM3053. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. GND1 1. …
RevisionE
File Format / SizePDF / 527 Kb
ADM3053. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. GND1 1. 20 GND2. NC 2. 19 VISOIN. GND1 3. 18 RS. RxD 4. 17 CANH. TxD 5
ADM3053 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS GND1 1 20 GND2 NC 2 19 VISOIN GND1 3 18 RS RxD 4 17 CANH TxD 5
link to page 15
ADM3053 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS GND1 1 20 GND2 NC 2 19 VISOIN GND1 3 18 RS RxD 4 17 CANH ADM3053 TxD 5 16 GND2 TOP VIEW VIO 6 (Not to Scale) 15 CANL GND1 7 14 VREF VCC 8 13 GND2 GND1 9 12 VISOOUT GND1 10 11 GND2 NOTES 1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN. 2. PIN 12 AND PIN 19 MUST BE
005
CONNECTED EXTERNALLY.
09293- Figure 4. Pin Configuration
Table 8. Pin Function Descriptions Pin No. Mnemonic Description
1, 3, 7, 9, 10 GND1 Ground, Logic Side. 2 NC No Connect. Do not connect to this pin. 4 RxD Receiver Output Data. 5 TxD Driver Input Data. 6 VIO iCoupler Power Supply. It is recommended that a 0.1 μF and a 0.01 μF decoupling capacitor be fitted between Pin 6 and GND1. See Figure 28 for layout recommendations. 8 VCC isoPower Power Supply. It is recommended that a 0.1 μF and a 10 μF decoupling capacitor be fitted between Pin 8 and Pin 9. 11, 13 GND2 Ground for Isolated DC-to-DC Converter. It is recommended to connect Pin 11 and Pin 13 together through one ferrite bead to the PCB ground. 12 VISOOUT Isolated Power Supply Output. This pin must be connected external y to VISOIN. It is recommended that a ferrite bead reservoir capacitor of 10 μF and a decoupling capacitor of 0.1 μF be fitted between Pin 12 and Pin 11. 14 VREF Reference Voltage Output. It is recommended not to connect to this pin. 15 CANL Low-Level CAN Voltage Input/Output. 16, 20 GND2 Ground, Bus Side. 17 CANH High-Level CAN Voltage Input/Output. 18 RS Slope Control Pin. Short this pin to GND2 (Pin 16 or Pin 20) for full speed operation. Use a weak pull-down for slope control. An input high places the transceiver in standby. This pin must not be left floating. 19 VISOIN Isolated Power Supply Input. This pin must be connected externally to VISOOUT. It is recommended this pin have a 0.1 μF capacitor to GND2 (Pin13 or Pin 11). Connect this pin through a ferrite bead and short trace length to VISOIN for operation. Rev. E | Page 8 of 18 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS SWITCHING CHARACTERISTICS REGULATORY INFORMATION INSULATION AND SAFETY-RELATED SPECIFICATIONS VDE 0884 INSULATION CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS CIRCUIT DESCRIPTION CAN TRANSCEIVER OPERATION SIGNAL ISOLATION POWER ISOLATION TRUTH TABLES THERMAL SHUTDOWN DC CORRECTNESS AND MAGNETIC FIELD IMMUNITY APPLICATIONS INFORMATION PCB LAYOUT EMI CONSIDERATIONS RS PIN INSULATION LIFETIME TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
