Datasheet LT3032 (Analog Devices) - 6
Description | Dual 150mA Positive/Negative Low Noise Low Dropout Linear Regulator |
Pages / Page | 24 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. INP-to-OUTP. INN-to-OUTN. Typical … |
File Format / Size | PDF / 410 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. INP-to-OUTP. INN-to-OUTN. Typical Dropout Voltage. Dropout Voltage. INP Quiescent Current
LT3032 Series
TYPICAL PERFORMANCE CHARACTERISTICS INP-to-OUTP INN-to-OUTN INP-to-OUTP Typical Dropout Voltage Typical Dropout Voltage Dropout Voltage
500 500 500 450 450 450 400 400 400 T 350 350 J = 125°C 350 T I J = 125°C L = 150mA 300 300 300 TAGE (mV) I 250 250 L = 50mA 250 200 T TJ = 25°C 200 J = 25°C 200 IL = 10mA 150 150 150 DROPOUT VOL DROPOUT VOLTAGE (mV) DROPOUT VOLTAGE (mV) IL = 1mA 100 100 100 50 50 50 0 0 0 0 20 40 60 80 100 120 140 160 0 –40 –80 –120 –160 –50 –25 0 25 50 75 100 125 LOAD CURRENT (mA) LOAD CURRENT (mA) TEMPERATURE (°C) 3032 G02 3032 G01 3032 G03
INN-to-OUTN Dropout Voltage INP Quiescent Current INN Quiescent Current
500 70 –60 IL = 0 (FIXED VOLTAGES) IL = 0 (FIXED VOLTAGES) 450 I I 60 L = 5µA (ADJUSTABLE) L = –5µA (ADJUSTABLE) –50 400 VSHDNP = VINP = VOUTP(NOMINAL) +1V (12V, 15V) 350 50 –40 V 300 SHDNN = VINN = VOUTN(NOMINAL) –1V IL = 150mA 40 V (12V, 15V) SHDNP = VINP = 6V 250 (5V, ADJ) –30 VSHDNN = VINN = –6V 200 30 (5V, ADJ) IL = 50mA –20 150 20 DROPOUT VOLTAGE (mV) IL = 10mA 100 QUIESCENT CURRENT (µA) QUIESCENT CURRENT (µA) I 10 –10 50 L = 1mA VSHDNN = 0V, VINN = –6V VSHDNP = 0V, VINP = 6V 0 0 0 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3032 G04 3032 G05 3032 G06
LT3032-3.3 OUTP Output Voltage LT3032-3.3 OUTN Output Voltage LT3032-5 OUTP Output Voltage
3.360 –3.360 5.100 IL = 1mA IL = –1mA IL = 1mA 3.345 –3.345 5.075 3.330 –3.330 5.050 3.315 –3.315 5.025 3.300 –3.300 5.000 3.285 –3.285 4.975 3.270 –3.270 4.950 OUTP OUTPUT VOLTAGE (V) OUTN OUTPUT VOLTAGE (V) OUTP OUTPUT VOLTAGE (V) 3.255 –3.255 4.925 3.240 –3.240 4.900 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 3032 G70 3032 G71 3032 G52 3032ff 6 For more information www.linear.com/LT3032 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
