Datasheet HMC988LP3E (Analog Devices) - 5
DescriptionProgrammable Clock Divider & Delay, DC - 4 GHz
Pages / Page22 / 5 — HMC988LP3E. PROGRAMMABLE CLOCK DIVIDER AND DELAY. DC - 4 GHz. Figure 7. …
HMC988LP3E. PROGRAMMABLE CLOCK DIVIDER AND DELAY. DC - 4 GHz. Figure 7. S-Parameters-S22 [4]. Figure 8. S-Parameters-S11 [4]
HMC988LP3E PROGRAMMABLE CLOCK DIVIDER AND DELAY DC - 4 GHz Figure 7 S-Parameters-S22 [4] Figure 8 S-Parameters-S11 [4]
HMC988LP3E
v04.1014
PROGRAMMABLE CLOCK DIVIDER AND DELAY DC - 4 GHz Figure 7. S-Parameters-S22 [4] Figure 8. S-Parameters-S11 [4]
0 0 -5 t -5 -10 M -15 s dB) dB) R ( -10 R ( E -20 E POW POW -25 n - -15 -30 io -35 t S22(Single-Ended) S11(Single-Ended) S22(Differnetial) S11(Differnetial) u -20 -40 100000 1000000 5E+06 1E+5 1E+6 5E+6 ib FREQUENCY (KHz) FREQUENCY (KHz) r
Figure 9. Input Sensitivity[5] Figure 10. Supply Voltage vs input Voltage [6]
t 200 3.6 is 180 160 pp) 3.4 V m 140 k D Recommended Operating Region 120 3.2 ) C V 100 R LEVEL ( E 80 VOUT ( 3 lo 60 VOUT(Regulated) C VOUT(non regulated) 40 INPUT POW 2.8 20 0 2.6 0 1 2 3 4 5 3 3.5 4 4.5 5 5.5 INPUT FREQUENCY (GHz) VIN (V)
Figure 11. Time Domain 1 GHz input, 500 MHz Output [7]
400 300 200 pp) V 100 m 0 PLITUTE ( -100 AM -200 -300 -400 0 210 500 1000 1500 2000 2500 3000 3500 4000 TIME (ps) [4] Measured with 200 Ω DC termination, 10 Ω series resistor in front, AC couple 1 nF 3.3 V [5] Measured single-ended. 120 Ω DC termination, 3.3 V HMC988lP5E AC coupled to 50 Ω instrument(Dso8104b) with divider bypass. EsD diode will start to turn on if maximum input power exceeds 12 dbm. [6] on Chip regulator enable mode measured at Pin CAP_3V Vs regulator bypass mode [7] Measured with 1 GHz 400 mVpp source as single ended input, HMC988lP3E div 2. board delay 210 ps Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
