Table 1. Pin DescriptionsHMC988LP3E v04.1014 PROGRAMMABLE CLOCK DIVIDER AND DELAYDC - 4 GHzTable 2. Pin Descriptions Pin number Function Description t 1,4,5 CHiP0, CHiP1, CHiP2 Chip sPi Address M 2,3 osCP, osCn Differential signal input s 6 GPo General Purpose output Pin & serial Data out 7 sDi serial Data input n - 8 sCk serial Data Clock 9 slE serial Data latch Enable io 10,11 DiVn, DiVP Differential output signal t 12 VDD3_DECAP Decoupling point for internally generated supply u 13 triG External sYnC or sliP Control Pin for slip/synchronization start ib 14 Fb_DECAP Decoupling point for regulator r 15 bGAP_DECAP Decoupling point for regulator t 16 VDD5 regulator input supply Voltage is k D C lo C Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com 6 Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
