Datasheet AD5116 (Analog Devices) - 8
Description | Single-Channel, 64-Position, Push Button, ±8% Resistor Tolerance, Nonvolatile Digital Potentiometer |
Pages / Page | 16 / 8 — AD5116. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 0.08. 0.02. 5kΩ, … |
Revision | B |
File Format / Size | PDF / 377 Kb |
AD5116. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 0.08. 0.02. 5kΩ, –40°C. 5kΩ, +25°C. 5kΩ, +125°C. 0.01. 0.06. 0.04. –0.01. SB –0.02. (L L
AD5116 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 0.08 0.02 5kΩ, –40°C 5kΩ, +25°C 5kΩ, +125°C 0.01 0.06 0 0.04 –0.01 ) ) 0.02 SB SB –0.02 (L L (L L IN 0 –0.03 R- DN 5kΩ, –40°C R- 5kΩ, +25°C –0.04 –0.02 5kΩ, +125°C 10kΩ, –40°C 10kΩ, +25°C –0.05 –0.04 10kΩ, +125°C 80kΩ, –40°C 80kΩ, +25°C –0.06 10kΩ, –40°C 10kΩ, +25°C 10kΩ, +125°C 80kΩ, +125°C 80kΩ, –40°C 80kΩ, +25°C 80kΩ, +125°C –0.06 –0.07
1 1
0 3 6 9 12 15 18 21 24 27 30 33 36 39 42 45 48 51 54 57 60 63
008
0
CODE (Decimal)
09657-
CODE (Decimal)
09657- Figure 8. R-INL vs. Code Figure 11. R-DNL vs. Code
0.08 0.02 5kΩ, –40°C 5kΩ, –40°C 5kΩ, +25°C 5kΩ, +125°C 5kΩ, +25°C 10kΩ, –40°C 10kΩ, +25°C 10kΩ, +125°C 0.06 5kΩ, +125°C 0.01 10kΩ, –40°C 10kΩ, +25°C 0.04 10kΩ, +125°C 0 80kΩ, –40°C 80kΩ, +25°C 0.02 80kΩ, +125°C ) –0.01 ) SB 0 SB (L L –0.02 (L L IN –0.02 DN –0.03 –0.04 –0.04 –0.06 –0.05 –0.08 80kΩ, –40°C 80kΩ, +25°C 80kΩ, +125°C –0.06 0 3 6 9 12 15 18 21 24 27 30 33 36 39 42 45 48 51 54 57 60 63
009
012
CODE (Decimal)
09657-
CODE (Decimal)
09657- Figure 9. INL vs. Code Figure 12. DNL vs. Code
800 V 1.2 DD = 2.3V V T V A = 25°C DD = 3.3V DD = 5V 700 V VDD = 3.3V DD = 5V VDD = 2.3V 1.0 600 ) A (n 500 mA) T 0.8 ( N E NT 400 0.6 CURR 300 Y CURRE L Y L PP 200 P U 0.4 S UP S 100 0.2 0 –100 0
010
–40 –25 –10 5 20 35 50 65 80 95 110 125 0.05 0.65 1.25 1.85 2.45 3.05 3.65 4.25 4.85
013
TEMPERATURE (°C)
09657-
DIGITAL INPUT VOLTAGE (V)
09657- Figure 10. Supply Current vs. Temperature Figure 13. Supply Current (IDD) vs. Digital Input Voltage Rev. B | Page 8 of 16 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Characteristics Interface Timing Specifications Timing Diagrams Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Theory of Operation RDAC Register Manual Increment Auto Scan Increment Low Wiper Resistance Feature EEPROM Automatic Save Enable Auto Save Manual Store End Scale Resistance Indicator RDAC Architecture Top Scale/Bottom Scale Architecture Programming the Variable Resistor Rheostat Operation—±8% Resistor Tolerance Programming the Potentiometer Divider Voltage Output Operation Terminal Voltage Operating Range Power-Up Sequence Layout and Power Supply Biasing Outline Dimensions Ordering Guide
