Datasheet X9312 (Intersil) - 4
ManufacturerIntersil
DescriptionDigitally Controlled Potentiometer (XDCP)
Pages / Page9 / 4 — X9312. ABSOLUTE MAXIMUM RATINGS. COMMENT. RECOMMENDED OPERATING …
File Format / SizePDF / 247 Kb
X9312. ABSOLUTE MAXIMUM RATINGS. COMMENT. RECOMMENDED OPERATING CONDITIONS. Temperature. Min. Max. Supply Voltage (VCC). Limits
X9312 ABSOLUTE MAXIMUM RATINGS COMMENT RECOMMENDED OPERATING CONDITIONS Temperature Min Max Supply Voltage (VCC) Limits
Temperature under bias .. -65°C to +135°C Stresses above those listed under “Absolute Maximum Storage temperature ... -65°C to +150°C Ratings” may cause permanent damage to the device. Voltage on CS, INC, U/D and VCC This is a stress rating only; functional operation of the with respect to VSS ... -1V to +7V device (at these or any other conditions above those ∆V = |VH - VL| ..15V listed in the operational sections of this specification) Lead temperature (soldering 10 seconds) ... 300°C is not implied. Exposure to absolute maximum rating IW (10 seconds) ...±8.8mA conditions for extended periods may affect device reliability.
RECOMMENDED OPERATING CONDITIONS Temperature Min. Max. Supply Voltage (VCC) Limits
Commercial 0°C +70°C X9312 5V ±10% Industrial -40°C +85°C
POTENTIOMETER CHARACTERISTICS
(Over recommended operating conditions unless otherwise stated.)
Limits Symbol Parameter Min. Typ. Max. Unit Test Conditions/Notes
End to end resistance tolerance ±20 % VVH VH terminal voltage VSS 15 V VSS = 0V VVL VL terminal voltage VSS 15 V VSS = 0V Power rating 25 mW RTOTAL ≥ 10kΩ Power rating 225 mW RTOTAL = 1kΩ RW Wiper resistance 40 100 Ω IW = 1mA, VCC = 5V IW Wiper current ±4.4 mA Noise -120 dBV Ref: 1kHz Resolution 1 % Absolute linearity(1) ±1 MI(3) Rw(n)(actual) - Rw(n)(expected) Relative linearity(2) ±0.2 MI(3) Rw(n+1) - [Rw(n) + MI] RTOTAL temperature coefficient ±300 ppm/°C Ratiometric temperature coefficient ±20 ppm/°C CH/CL/CW Potentiometer capacitances 10/10/25 pF See circuit #3 Notes: (1) Absolute linearity is utilized to determine actual wiper voltage versus expected voltage = (Vw(n)(actual) - Vw(n)(expected)) = ±1 Ml Maximum. (2) Relative linearity is a measure of the error in step size between taps = RW(n+1 - [Rw(n) + Ml] = ±0.2 Ml. (3) 1 Ml = Minimum Increment = RTOT/99. 4 FN8176.0 March 15, 2005
