Datasheet BCR602 (Infineon) - 2
ManufacturerInfineon
Description60V linear LED controller IC for dimmable LED
Pages / Page15 / 2 — BCR602 hot plug IC with dimming. Description. Table 1. Part information. …
Revision01_01
File Format / SizePDF / 478 Kb
BCR602 hot plug IC with dimming. Description. Table 1. Part information. Type. Package. Configuration. Marking code
BCR602 hot plug IC with dimming Description Table 1 Part information Type Package Configuration Marking code
60V Linear Current Control PG-SOT23-6 n.a. 602 Chip BCR602
BCR602 is a linear LED controller IC regulating the LED current by means of an external driver transistor. BCR602 supports use of NPN bipolar transistors and NMOSFETs to cover a wide LED current and power range up to several hundred mA. The LED current is fully scalable by dimensioning an external current sense resistor. BCR602 suppresses the voltage ripple of the power supply driving a constant LED current for better light quality. The LED current can be dimmed by resistors as well as analog or digital PWM voltages connected to the Multi Function Input Output (MFIO) pin. The embedded hot plug protection allows plug in and plug out of any LED load during operation. The overtemperature protection will dim the LED current if the BCR602 junction temperature threshold is exceeded. In this case the LED current will be reduced to 30% of the nominal current. Once the junction temperature drops below the temperature hysteresis nominal LED current is resumed. The BCR602 is a perfect fit for LED applications by combining small form factor with low cost. Through its higher integration, BOM savings and ensuring long lifetime of LEDs, this controller has many advantages compared to discrete solutions. Datasheet 2 Revision 1.1 2018-12-3 Document Outline Features Protection features Target applications Advantages with respect to discrete solutions Product validation Device information Description Table of contents 1 Pin configuration 2 Functional description 3 Thermal characteristics 4 Absolute maximum ratings 5 Operating conditions 6 Electrical characteristics 7 Package information 8 References Revision history Disclaimer
