Datasheet MMBT3904 (Diodes) - 2
ManufacturerDiodes
DescriptionNPN
Pages / Page7 / 2 — MMBT3904. Absolute Maximum Ratings. Characteristic. Symbol. Value. Unit. …
File Format / SizePDF / 409 Kb
MMBT3904. Absolute Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics. ESD Ratings. JEDEC Class
MMBT3904 Absolute Maximum Ratings Characteristic Symbol Value Unit Thermal Characteristics ESD Ratings JEDEC Class
(@TA = +25°C, unless otherwise specified.)
Collector-Base Voltage VCBO 60 V Collector-Emitter Voltage VCEO 40 V Emitter-Base Voltage VEBO 6 V Collector Current IC 200 mA
(Note 6) 310 Power Dissipation PD mW (Note 7) 350 (Note 6) 403 Thermal Resistance, Junction to Ambient RθJA °C/W (Note 7) 357 Thermal Resistance, Junction to Leads (Note 8) RθJL 350 °C/W Operating and Storage Temperature Range TJ,TSTG -55 to +150 °C
ESD Ratings
(Note 9)
Characteristic Symbol Value Unit JEDEC Class
Electrostatic Discharge - Human Body Model ESD HBM 4,000 V 3A Electrostatic Discharge - Machine Model ESD MM 400 V C Notes: 6. For a device mounted on minimum recommended pad layout 1oz copper that is on a single-sided FR4 PCB; device is measured under still air conditions whilst operating in a steady-state. 7. Same as Note 6, except the device is mounted on 15 mm x 15mm 1oz copper. 8. Thermal resistance from junction to solder-point (at the end of the leads). 9. Refer to JEDEC specification JESD22-A114 and JESD22-A115. MMBT3904 2 of 7 March 2017 Document number: DS30036 Rev. 25 - 2
www.diodes.com
© Diodes Incorporated
