Datasheet HMC788A (Analog Devices)
Description0.01 GHz to 10 GHz, MMIC, GaAs, pHEMT RF Gain Block
Pages / Page12 / 1 — 0.01 GHz to 10 GHz, MMIC, GaAs, pHEMT. RF Gain Block. Data Sheet. …
RevisionC
File Format / SizePDF / 213 Kb
0.01 GHz to 10 GHz, MMIC, GaAs, pHEMT. RF Gain Block. Data Sheet. HMC788A. FEATURES. FUNCTIONAL BLOCK DIAGRAM. Gain: 14 dB typical
Datasheet HMC788A Analog Devices, Revision: C
0.01 GHz to 10 GHz, MMIC, GaAs, pHEMT RF Gain Block Data Sheet HMC788A FEATURES FUNCTIONAL BLOCK DIAGRAM Gain: 14 dB typical HMC788A Operational frequency range: 0.01 GHz to 10 GHz NIC 1 6 NIC Input/output internally matched to 50 Ω RF 2 5 IN RFOUT High input linearity GND 3 4 NIC 1 dB compression (P1dB): 20 dBm typical PACKAGE Output third-order intercept (OIP3): 33 dBm typical
001
BASE Supply voltage: 5 V typical
16204- Figure 1.
2 mm × 2 mm, 6-lead lead frame chip scale package APPLICATIONS Cellular, 3G, LTE, WiMAX, and 4G LO driver applications Microwave radio Test and measurement equipment Ultra wideband (UWB) communications GENERAL DESCRIPTION
The HMC788A is a 0.01 GHz to 10 GHz, gain block, monolithic The HMC788A offers 14 dB of gain and an output IP3 of microwave integrated circuit (MMIC) amplifier using gallium 33 dBm while requiring only 76 mA from a 5 V supply. arsenide (GaAs), pseudomorphic high electron mobility transistor The Darlington feedback pair exhibits reduced sensitivity to (pHEMT) technology. normal process variations and yields excellent gain stability over This 2 mm × 2 mm LFCSP amplifier can be used as either a temperature while requiring a minimal number of external bias cascadable 50 Ω gain stage, or to drive the local oscillator (LO) port components. of many of the single and double balanced mixers from Analog Devices, Inc. with up to 20 dBm output power.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2017–2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Basic Connections Applications Information Evaluation PCB Outline Dimensions Ordering Guide
