Datasheet ADL5611 (Analog Devices) - 5
Description | 30 MHz to 6 GHz RF/IF Gain Block |
Pages / Page | 16 / 5 — Data Sheet. ADL5611. Parameter. Test Conditions/Comments. Min. Typ. Max. … |
Revision | B |
File Format / Size | PDF / 503 Kb |
Data Sheet. ADL5611. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit. TYPICAL SCATTERING PARAMETERS (S-PARAMETERS)
Data Sheet ADL5611 Parameter Test Conditions/Comments Min Typ Max Unit
POWER INTERFACE Supply Voltage VPOS 4.75 5 5.25 V Supply Current 94 124 mA vs. Temperature −40°C ≤ TA ≤ +105°C −7/+14 mA Power Dissipation VPOS = 5 V 470 mW 1 Noise figure specified includes printed circuit board (PCB) traces losses.
VPOS = 5 V and TA = 25°C.
Table 2. Frequency S11 S21 S12 S22 (MHz) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
30 −19.413 −26.158 +21.776 +172.769 −27.133 +0.556 −11.297 −165.214 50 −13.165 +18.866 +20.450 +161.606 −28.149 −13.136 −7.839 −163.448 100 −7.702 −16.728 +17.424 +169.845 −31.453 −6.433 −5.303 −189.380 200 −10.283 −70.711 +20.615 +170.893 −28.530 −3.592 −7.558 −220.163 300 −13.623 −97.401 +21.750 +153.718 −27.648 −17.328 −9.628 −229.758 400 −16.531 −116.624 +22.133 +137.323 −27.393 −29.469 −10.723 −234.863 500 −13.489 −133.038 +21.878 −227.398 −27.654 −30.240 −9.139 −242.984 600 −15.012 −155.101 +22.109 −242.602 −27.407 −41.040 −9.456 −252.814 700 −16.953 −173.278 +22.166 −258.309 −27.340 −52.626 −9.852 −259.624 800 −18.750 −191.016 +22.175 −273.359 −27.310 −63.591 −10.087 −266.406 900 −20.402 −209.005 +22.157 −287.987 −27.272 −74.251 −10.220 −273.138 1000 −22.020 −226.338 +22.123 −302.271 −27.262 −84.772 −10.281 −280.106 1100 −23.568 −243.133 +22.077 −316.366 −27.273 −94.790 −10.316 −286.874 1200 −25.331 −258.964 +22.018 −330.209 −27.269 −104.782 −10.341 −293.925 1300 −27.267 −272.170 +21.957 −343.987 −27.264 −114.842 −10.329 −300.962 1400 −29.729 −280.677 +21.882 −357.634 −27.273 −124.700 −10.350 −308.089 1500 −33.265 −281.069 +21.812 −371.163 −27.273 −134.354 −10.363 −314.919 1600 −35.854 −260.621 +21.737 −384.666 −27.266 −144.166 −10.357 −321.662 1700 −34.321 −226.683 +21.648 −398.040 −27.267 −154.033 −10.400 −328.324 1800 −29.745 −218.694 +21.569 −411.423 −27.245 −163.652 −10.392 −334.645 1900 −26.887 −221.152 +21.438 −424.771 −27.233 −173.766 −10.531 −341.717 2000 −24.113 −228.131 +21.331 −438.049 −27.225 −183.324 −10.566 −347.988 2100 −21.301 −235.040 +21.256 −451.001 −27.272 −193.034 −10.674 −352.991 2200 −19.164 −245.484 +21.164 −464.099 −27.274 −202.461 −10.724 −358.726 2300 −17.568 −257.372 +21.078 −477.290 −27.248 −212.036 −10.708 −364.342 2400 −16.338 −268.596 +20.965 −490.408 −27.207 −221.732 −10.706 −370.531 2500 −15.187 −279.362 +20.863 −503.418 −27.219 −231.237 −10.737 −376.605 2600 −14.370 −290.528 +20.734 −516.421 −27.195 −240.889 −10.755 −383.283 2700 −13.733 −301.461 +20.606 −529.269 −27.127 −250.483 −10.775 −390.170 2800 −13.062 −311.936 +20.519 −541.969 −27.084 −259.695 −10.809 −397.037 2900 −12.653 −322.355 +20.435 −554.516 −26.970 −269.348 −10.888 −404.594 3000 −12.418 −332.177 +20.380 −567.048 −26.772 −279.469 −11.086 −412.962 3100 −12.019 −342.619 +20.411 −579.843 −26.724 −289.424 −11.163 −420.818 3200 −11.809 −354.255 +20.422 −592.914 −26.607 −299.778 −11.348 −430.470 3300 −11.972 −366.792 +20.411 −606.400 −26.511 −309.746 −11.533 −440.976 3400 −12.388 −377.671 +20.419 −619.528 −26.359 −320.482 −12.017 −452.391 3500 −12.849 −390.154 +20.412 −633.251 −26.200 −331.064 −12.489 −465.304 Rev. B | Page 5 of 16 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS (S-PARAMETERS) ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 6 GHz FREQUENCY BAND 30 MHz TO 500 MHz FREQUENCY BAND GENERAL APPLICATIONS INFORMATION BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN W-CDMA ACPR PERFORMANCE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
