Datasheet ADL5611 (Analog Devices) - 10
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page16 / 10 — ADL5611. Data Sheet. 30 MHz TO 500 MHz FREQUENCY BAND. ) m. , dB. 3 (dB. …
RevisionB
File Format / SizePDF / 503 Kb
ADL5611. Data Sheet. 30 MHz TO 500 MHz FREQUENCY BAND. ) m. , dB. 3 (dB. OIP3 (dBm). 30MHz. , OIP. 140MHz. 1dB. , P. GAIN (dB). dBm). IP3 ( O. 350MHz
ADL5611 Data Sheet 30 MHz TO 500 MHz FREQUENCY BAND ) m , dB 3 (dB OIP3 (dBm) 30MHz , OIP 140MHz 1dB , P GAIN (dB) dBm) IP3 ( O 350MHz
ADL5611 Data Sheet 30 MHz TO 500 MHz FREQUENCY BAND 45 45 ) m 40 , dB 40 35 3 (dB OIP3 (dBm) 30MHz 30 35 , OIP 140MHz 1dB 25 , P GAIN (dB) dBm) 30 IN 20 IP3 ( O 350MHz E, GA 15 R P1dB (dBm) 25 10 E FIGU 20 5 OIS N NOISE FIGURE (dB) 0 15 0 50 100 150 200 250 300 350 400 450 500
109
–5 –3 –1 1 3 5
112
FREQUENCY (MHz)
11508-
POUT PER TONE (dBm)
11508- Figure 9. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency, Figure 12. OIP3 vs. Output Power (POUT) and Frequency, Low Frequency Configuration Low Frequency Configuration
25 0 –40°C –5 20 +105°C S22 –10 15 +25°C +85°C (dB) S11 –15 (dB) IN ETERS GA 10 –20 PARAM S- –25 S12 5 –30 0 –35 0 50 100 150 200 250 300 350 400 450 500
110
113
FREQUENCY (MHz)
11508-
FREQUENCY (MHz)
11508- Figure 10. Gain vs. Frequency and Temperature, Figure 13. Output Return Loss (S22), Input Return Loss (S11), and Low Frequency Configuration Reverse Isolation (S12) vs. Frequency, Low Frequency Configuration
45 45 8 40 40 7 35 35 6 30 30 ) +105°C 5 –40°C 25 25 E (dB R dBm) dBm) –40°C +85°C 4 +25°C 20 +25°C 20 B ( IP3 ( O +105°C P1d E FIGU 3 15 15 OIS N 10 10 2 +85°C 5 5 1 0 0 0 0 50 100 150 200 250 300 350 400 450 500
1 11
114
FREQUENCY (MHz)
11508-
FREQUENCY (MHz)
11508- Figure 11. OIP3 and P1dB vs. Frequency and Temperature, Figure 14. Noise Figure vs. Frequency and Temperature, Low Frequency Configuration Low Frequency Configuration Rev. B | Page 10 of 16 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS (S-PARAMETERS) ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 6 GHz FREQUENCY BAND 30 MHz TO 500 MHz FREQUENCY BAND GENERAL APPLICATIONS INFORMATION BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN W-CDMA ACPR PERFORMANCE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
