Datasheet ADL5611 (Analog Devices) - 3
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page16 / 3 — Data Sheet. ADL5611. SPECIFICATIONS. Table 1. Parameter. Test …
File Format / SizePDF / 503 Kb
Data Sheet. ADL5611. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADL5611 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 link to page 5
VPOS = 5 V and TA = 25°C, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
OVERALL FUNCTION Frequency Range 30 6000 MHz FREQUENCY = 30 MHz Gain 21.8 dB Output 1 dB Compression Point (P1dB) 16.0 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 0 dBm per tone 27.6 dBm Noise Figure1 3.9 dB FREQUENCY = 140 MHz Gain 18.9 dB vs. Frequency ±10 MHz ±0.42 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.45 dB vs. Supply 4.75 V to 5.25 V ±0.09 dB Output 1 dB Compression Point 16.3 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 0 dBm per tone 27.2 dBm Noise Figure1 3.3 dB FREQUENCY = 350 MHz Gain 22.0 dB vs. Frequency ±10 MHz ±0.04 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.28 dB vs. Supply 4.75 V to 5.25 V ±0.06 dB Output 1 dB Compression Point 20.9 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 0 dBm per tone 34.0 dBm Noise Figure1 2.4 dB FREQUENCY = 700 MHz Gain 22.2 dB vs. Frequency ±50 MHz ±0.02 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.26 dB vs. Supply 4.75 V to 5.25 V ±0.08 dB Output 1 dB Compression Point 21.0 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 0 dBm per tone 39.6 dBm Noise Figure1 2.1 dB FREQUENCY = 900 MHz Gain 21.2 22.2 23.2 dB vs. Frequency ±50 MHz ±0.02 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.25 dB vs. Supply 4.75 V to 5.25 V ±0.10 dB Output 1 dB Compression Point 21.0 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 0 dBm per tone 40.0 dBm Noise Figure1 2.1 dB FREQUENCY = 1900 MHz Gain 20.4 21.4 22.4 dB vs. Frequency ±50 MHz ±0.07 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.34 dB vs. Supply 4.75 V to 5.25 V ±0.20 dB Output 1 dB Compression Point 20.6 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 0 dBm per tone 37.0 dBm Noise Figure1 2.4 dB Rev. B | Page 3 of 16 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS (S-PARAMETERS) ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 6 GHz FREQUENCY BAND 30 MHz TO 500 MHz FREQUENCY BAND GENERAL APPLICATIONS INFORMATION BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN W-CDMA ACPR PERFORMANCE EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
