link to page 5 link to page 5 link to page 5 link to page 5 link to page 5 ADL5610Data SheetParameterTest Conditions/CommentsMinTypMaxUnit FREQUENCY = 2140 MHz Gain 17.8 dB vs. Frequency ±50 MHz ±0.03 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.25 dB vs. Supply 4.75 V to 5.25 V ±0.13 dB Output 1 dB Compression Point 19.9 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 3 dBm per tone 36.8 dBm Noise Figure1 2.7 dB FREQUENCY = 2600 MHz Gain 17.5 dB vs. Frequency ±50 MHz ±0.03 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.28 dB vs. Supply 4.75 V to 5.25 V ±0.15 dB Output 1 dB Compression Point 18.7 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 3 dBm per tone 33.5 dBm Noise Figure1 2.8 dB FREQUENCY = 3500 MHz Gain 17.6 dB vs. Frequency ±50 MHz ±0.04 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.45 dB vs. Supply 4.75 V to 5.25 V ±0.19 dB Output 1 dB Compression Point 17.4 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 3 dBm per tone 29.4 dBm Noise Figure1 3.0 dB FREQUENCY = 4000 MHz Gain 17.9 dB vs. Frequency ±50 MHz ±0.04 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±0.84 dB vs. Supply 4.75 V to 5.25 V ±0.24 dB Output 1 dB Compression Point 16.4 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 3 dBm per tone 27.6 dBm Noise Figure1 3.2 dB FREQUENCY = 5000 MHz Gain 15.3 dB vs. Frequency ±50 MHz ±0.11 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±1.27 dB vs. Supply 4.75 V to 5.25 V ±0.33 dB Output 1 dB Compression Point 15.7 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 3 dBm per tone 26.1 dBm Noise Figure 4.4 dB FREQUENCY = 5800 MHz Gain 13.2 dB vs. Frequency ±50 MHz ±0.08 dB vs. Temperature −40°C ≤ TA ≤ +105°C ±1.36 dB vs. Supply 4.75 V to 5.25 V ±0.33 dB Output 1 dB Compression Point 12.5 dBm Output Third-Order Intercept Δf = 1 MHz, POUT = 3 dBm per tone 21.2 dBm Noise Figure1 6.1 dB Rev. B | Page 4 of 16 Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 6 GHz Frequency Band 30 MHz to 500 MHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
