Datasheet ADL5610 (Analog Devices) - 9
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page16 / 9 — Data Sheet. ADL5610. TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 6 GHz …
RevisionB
File Format / SizePDF / 558 Kb
Data Sheet. ADL5610. TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 6 GHz FREQUENCY BAND. OIP3 (dBm). m 40. , dB. 900MHz. 3 (dB. 700MHz
Data Sheet ADL5610 TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 6 GHz FREQUENCY BAND OIP3 (dBm) m 40 , dB 900MHz 3 (dB 700MHz
Data Sheet ADL5610 TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 6 GHz FREQUENCY BAND 45 45 ) OIP3 (dBm) m 40 , dB 40 35 900MHz 3 (dB 700MHz 30 35 , OIP 1900MHz 1dB 25 2140MHz , P dBm) 30 IN P1dB (dBm) 20 2600MHz IP3 ( 3500MHz O E, GA GAIN (dB) 15 5000MHz R 25 4000MHz 5800MHz 10 E FIGU 20 5 OIS NOISE FIGURE (dB) N 0 15 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0
103
–4 –2 0 2 4 6
106
FREQUENCY (GHz)
11507-
POUT PER TONE (dBm)
11507- Figure 3. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency Figure 6. OIP3 vs. Output Power (POUT) and Frequency
25 0 –5 20 –40°C +85°C –10 ) +25°C B S22 15 –15 S (d dB) ER N ( +105°C –20 AI MET S12 G 10 A R –25 S-PA S11 –30 5 –35 0 –40 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0
104
107
FREQUENCY (GHz)
11507-
FREQUENCY (GHz)
11507- Figure 4. Gain vs. Frequency and Temperature Figure 7. Output Return Loss (S22), Input Return Loss (S11), and Reverse Isolation (S12) vs. Frequency
45 45 8 40 40 7 +85°C 35 35 6 ) 30 30 5 E (dB 25 25 R dBm) +105°C dBm) +85°C 4 IP3 ( 20 +25°C –40°C 20 B ( +105°C O P1d E FIGU 3 15 15 OIS N 10 10 2 –40°C +25°C 5 5 1 0 0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0
105
108
FREQUENCY (GHz)
11507-
FREQUENCY (GHz)
11507- Figure 5. OIP3 and P1dB vs. Frequency and Temperature Figure 8. Noise Figure vs. Frequency and Temperature Rev. B | Page 9 of 16 Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 6 GHz Frequency Band 30 MHz to 500 MHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
