ADL5545Data SheetParameterTest Conditions/CommentsMinTypMaxUnit FREQUENCY = 2140 MHz Gain 21.1 21.8 22.4 dB vs. Frequency ±50 MHz ±0.09 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.7 dB vs. Supply 4.75 V to 5.25 V ±0.17 dB Output 1 dB Compression Point 16.2 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 35.7 dBm Noise Figure 3.5 dB FREQUENCY = 2600 MHz Gain 20.1 20.9 21.7 dB vs. Frequency ±50 MHz ±0.09 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.7 dB vs. Supply 4.75 V to 5.25 V ±0.16 dB Output 1 dB Compression Point 15.7 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 34.6 dBm Noise Figure 3.6 dB FREQUENCY = 3500 MHz Gain 19.0 19.7 20.4 dB vs. Frequency ±50 MHz ±0.10 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.8 dB vs. Supply 4.75 V to 5.25 V ±0.17 dB Output 1 dB Compression Point 14.5 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 33.7 dBm Noise Figure 4.0 dB FREQUENCY = 4000 MHz Gain 17.8 18.6 19.4 dB vs. Frequency ±50 MHz ±0.14 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±1.0 dB vs. Supply 4.75 V to 5.25 V ±0.19 dB Output 1 dB Compression Point 13.1 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 29.0 dBm Noise Figure 4.6 dB FREQUENCY = 5000 MHz Gain 16.8 dB vs. Frequency ±50 MHz ±0.05 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±1.2 dB vs. Supply 4.75 V to 5.25 V ±0.20 dB Output 1 dB Compression Point 9.9 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 31.8 dBm Noise Figure 4.8 dB FREQUENCY = 5800 MHz Gain 15.9 dB vs. Frequency ±50 MHz ±0.20 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±1.3 dB vs. Supply 4.75 V to 5.25 V ±0.20 dB Output 1 dB Compression Point 9.4 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = −3 dBm per tone 28.4 dBm Noise Figure 5.2 dB POWER INTERFACE VPOS Supply Voltage 4.75 5 5.25 V Supply Current 56 70 mA vs. Temperature −40°C ≤ TA ≤ +85°C −6 mA Power Dissipation VPOS = 5 V 280 mW Rev. A | Page 4 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
