20 /10 — ADL5545. Data Sheet. 100 MHz TO 500 MHz FREQUENCY BAND. ) m. , dB. OIP3. …
Revision
A
PDF / 385 Kb
ADL5545. Data Sheet. 100 MHz TO 500 MHz FREQUENCY BAND. ) m. , dB. OIP3. dB (. GAIN. , OIP. 140MHz. dB 1. Bm). , P. 3 (. P1dB. IP O. 350MHz. , GA. E R. FIGU
ADL5545Data Sheet100 MHz TO 500 MHz FREQUENCY BAND4045) m35, dBOIP340dB (303GAIN, OIP2535140MHzdB 1Bm), P20dIN3 (P1dBIP O30350MHz, GA15E R10FIGU25E5NOISE FIGUREOIS N0200.100.150.200.250.300.350.400.450.50 009 –5.0–2.502.55.0 012 FREQUENCY (GHz) 1385- 1 POUT PER TONE (dBm) 1385- 1 Figure 9. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency, Figure 12. OIP3 vs. Output Power (POUT) and Frequency, Low Frequency Configuration Low Frequency Configuration 26.0025.5–5–40°C+25°C25.0)–10B24.5S (dB)–15dER24.0N ( AIMETS11G+85°CA–20R23.5+105°CS22S-PA–2523.0S1222.5–3022.0–350.100.150.200.250.300.350.400.450.50 010 0.100.150.200.250.300.350.400.450.50 013 FREQUENCY (GHz) 1385- 1 FREQUENCY (GHz) 11385- Figure 10. Gain vs. Frequency and Temperature, Figure 13. Input Return Loss (S11), Output Return Loss (S22), and Reverse Low Frequency Configuration Isolation (S12) vs. Frequency, Low Frequency Configuration 40406.0+25°C–40°C+85°C5.535355.0)3030dB4.5( EBm)+105°CBm)R+85°Cdd25254.0+105°CB (3 (FIGU1dIPEPO3.52020OIS+25°CN+25°C+85°C3.0–40°C15152.5+105°C–40°C10102.0 1 1 0.100.150.200.250.300.350.400.450.50 0 0.100.150.200.250.300.350.400.450.50 014 FREQUENCY (GHz) 1385- 1 FREQUENCY (GHz) 11385- Figure 11. P1dB and OIP3 vs. Frequency and Temperature, Figure 14. Noise Figure vs. Frequency and Temperature, Low Frequency Configuration Low Frequency Configuration Rev. A | Page 10 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
