Datasheet ADL5545 (Analog Devices) - 9
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page20 / 9 — Data Sheet. ADL5545. TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz …
File Format / SizePDF / 385 Kb
Data Sheet. ADL5545. TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND. ) m. 700MHz. , dB. 900MHz. OIP3. dB (. , OIP
Data Sheet ADL5545 TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND ) m 700MHz , dB 900MHz OIP3 dB ( , OIP
Data Sheet ADL5545 TYPICAL PERFORMANCE CHARACTERISTICS 500 MHz TO 4 GHz FREQUENCY BAND 40 45 ) m 700MHz 35 , dB 900MHz OIP3 40 dB ( 30 3 , OIP 25 2140MHz 35 dB 1 GAIN Bm) d , P 20 IN 3 ( 2600MHz 1900MHz P1dB IP O 30 , GA 15 E R 10 4000MHz FIGU 25 E 5 NOISE FIGURE 3500MHz OIS N 0 20 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
003
–5.0 –2.5 0 2.5 5.0
006
FREQUENCY (GHz)
1385- 1
POUT PER TONE (dBm)
1385- 1 Figure 3. Noise Figure, Gain, P1dB, and OIP3 vs. Frequency Figure 6. OIP3 vs. Output Power (POUT) and Frequency
25 0 –40°C 24 –5 +25°C 23 22 ) –10 B 21 S (d B) –15 d +85°C ER S11 S22 20 N ( AI MET G +105°C A –20 19 R 18 S-PA –25 S12 17 –30 16 15 –35 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
004
007
FREQUENCY (GHz)
1385- 1
FREQUENCY (GHz)
11385- Figure 4. Gain vs. Frequency and Temperature Figure 7. Input Return Loss (S11), Output Return Loss (S22), and Reverse Isolation (S12) vs. Frequency
40 40 6.0 +25°C –40°C 5.5 35 35 5.0 ) +85°C 30 30 dB 4.5 ( E +105°C Bm) +85°C Bm) R d d 25 25 4.0 B ( 3 ( +105°C FIGU 1d IP E +25°C P O 3.5 20 20 OIS +25°C N 3.0 +85°C +105°C –40°C 15 15 2.5 –40°C 10 10 2.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
005
008
FREQUENCY (GHz)
11385-
FREQUENCY (GHz)
11385- Figure 5. P1dB and OIP3 vs. Frequency and Temperature Figure 8. Noise Figure vs. Frequency and Temperature Rev. A | Page 9 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
