Datasheet ADL5545 (Analog Devices) - 6
Description30 MHz to 6 GHz RF/IF Gain Block
Pages / Page20 / 6 — ADL5545. Data Sheet. Frequency. S11. S21. S12. S22. (MHz). Magnitude (dB) …
RevisionA
File Format / SizePDF / 385 Kb
ADL5545. Data Sheet. Frequency. S11. S21. S12. S22. (MHz). Magnitude (dB) Angle (°). Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
ADL5545 Data Sheet Frequency S11 S21 S12 S22 (MHz) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
ADL5545 Data Sheet Frequency S11 S21 S12 S22 (MHz) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°) Magnitude (dB) Angle (°)
4600 0.403438 175.5599 8.049058 −44.1889 0.050324 −92.3473 0.340214 −178.955 4700 0.401499 171.8158 7.964614 −48.7045 0.050239 −95.0828 0.350676 −178.928 4800 0.402691 167.514 7.806924 −53.0729 0.050117 −98.0907 0.356655 −179.069 4900 0.406951 163.0433 7.595136 −57.4387 0.049987 −101.172 0.357806 −179.375 5000 0.406358 157.9584 7.49582 −61.8963 0.049721 −103.942 0.354643 −179.768 5100 0.411878 152.676 7.317407 −66.1646 0.049487 −107.027 0.348613 178.5262 5200 0.419117 147.3732 7.122278 −70.4926 0.049173 −110.061 0.341386 175.9255 5300 0.424908 141.8343 6.989999 −74.8425 0.048744 −112.912 0.335864 172.3498 5400 0.436811 136.4786 6.79254 −79.1925 0.048313 −116.144 0.334212 167.6101 5500 0.448229 131.1618 6.608538 −83.5489 0.047742 −119.197 0.337723 162.7581 5600 0.458741 125.8601 6.460463 −87.804 0.047224 −122.079 0.346452 158.0309 5700 0.476482 121.0845 6.279033 −92.0021 0.046819 −125.265 0.359399 153.2462 5800 0.493574 116.483 6.126505 −96.2338 0.046407 −128.278 0.372718 149.2789 5900 0.510235 112.0889 6.015478 −100.445 0.046071 −131.302 0.385573 145.8469 6000 0.529772 108.3059 5.87094 −104.55 0.045766 −134.468 0.395866 142.478 Rev. A | Page 6 of 20 Document Outline Features Functional Block Diagram General Description Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 500 MHz to 4 GHz Frequency Band 100 MHz to 500 MHz Frequency Band 4 GHz to 6 GHz Frequency Band General Applications Information Basic Connections Soldering Information and Recommended PCB Land Pattern Operation Down to 30 MHz W-CDMA ACPR Performance Evaluation Board Outline Dimensions Ordering Guide
