Datasheet HMC3587LP3BE (Analog Devices)
DescriptionHBT GAIN BLOCK MMIC AMPLIFIER, 4 - 10 GHz
Pages / Page8 / 1 — HMC3587LP3BE. HBT GAIN BLOCK. MMIC AMPLIFIER, 4 - 10 GHz. Typical …
File Format / SizePDF / 506 Kb
HMC3587LP3BE. HBT GAIN BLOCK. MMIC AMPLIFIER, 4 - 10 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC3587LP3BE Analog Devices
HMC3587LP3BE
v02.0717
HBT GAIN BLOCK MMIC AMPLIFIER, 4 - 10 GHz Typical Applications Features
The HmC3587lp3Be is ideal for: High output ip3: +25 dBm T • Cel ular / pCs / 3G single positive supply: +5V m low noise figure: 3.5 dB [1] s • fixed wireless & wlAn 12 lead 3x3 mm smT package: 9mm² • CATV, Cable modem & DBs r - • microwave radio & Test equipment e • if & rf Applications w o p
The HmC3587lp3Be is a HBT Gain Block mmiC r & amplifier covering 4 GHz to 10 GHz and packaged in A e a 3x3 mm plastic Qfn smT package. This versatile amplifier can be used as a cascadable if or rf gain stage in 50 ohm applications. The HmC3587lp3Be lin delivers 14.5 dB gain, and +13 dBm output p1dB with only 3.5 dB noise figure. s - r ie lif p m A
Electrical Specifications, T = +25° C, Vcc = 5V, Vpd = 5V A
parameter min. Typ. max. min. Typ. max. Units frequency range 4 - 5 5 - 10 GHz Gain [1] 12.5 14.5 13 15 dB Gain Variation over Temperature 0.009 0.012 dB / °C input return loss 14 12 dB output return loss 12 13 dB output power for 1 dB Compression (p1dB) 8 11 10.5 13 dBm output Third order intercept (ip3) 23 25 dBm (pout = 0 dBm per tone, 1 mHz spacing) noise figure [1] 4.5 6 3.5 6 dB supply Current 1 (icc) 43 60 43 60 mA supply Current 2 (ipd) 4 5 4 5 mA [1] Board loss subtracted out. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Second Harmonics vs. Pout Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Temperature @ Pout = 18 dBm Power Dissipation Power Compression @ 10 GHz Psat vs. Vdd P1dB vs. Vdd Psat vs. Temperature P1dB vs. Temperature Noise Figure vs. Frequency Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Gain & Return Loss Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
