Datasheet HMC3587LP3BE (Analog Devices) - 4
DescriptionHBT GAIN BLOCK MMIC AMPLIFIER, 4 - 10 GHz
Pages / Page8 / 4 — HMC3587LP3BE. HBT GAIN BLOCK. MMIC AMPLIFIER, 4 - 10 GHz. Reverse …
File Format / SizePDF / 506 Kb
HMC3587LP3BE. HBT GAIN BLOCK. MMIC AMPLIFIER, 4 - 10 GHz. Reverse Isolation. Absolute Maximum Ratings
HMC3587LP3BE HBT GAIN BLOCK MMIC AMPLIFIER, 4 - 10 GHz Reverse Isolation Absolute Maximum Ratings
HMC3587LP3BE
v02.0717
0 -10 +25C +85C T -40C ) -20 m (dB N -30 s IO T LA -40 O IS r - -50 e -60 w -70 o 4 5 6 7 8 9 10 p FREQUENCY (GHz) r & A
e Drain Bias Voltage 6 Vdc rf input power (rfin) +12 dBm lin Channel Temperature 150 °C Continuous pdiss (T=85 °C) 512 mw s - (derate 7.87 mw/ °C Above +85 °C) r Thermal resistance 127 °C/w (channel to ground paddle) ie storage Temperature -65 to 150 °C operating Temperature -40 to +85 °C lif esD sensitivity (HBm) Class 1A p m A For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
4
Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Second Harmonics vs. Pout Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Temperature @ Pout = 18 dBm Power Dissipation Power Compression @ 10 GHz Psat vs. Vdd P1dB vs. Vdd Psat vs. Temperature P1dB vs. Temperature Noise Figure vs. Frequency Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Gain & Return Loss Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
