Datasheet ADL5535 (Analog Devices)
Description | 20 MHz TO 1.0 GHz IF Gain Block |
Pages / Page | 16 / 1 — 20 MHz to 1.0 GHz IF Gain Block. Data Sheet. ADL5535. FEATURES. … |
Revision | A |
File Format / Size | PDF / 384 Kb |
20 MHz to 1.0 GHz IF Gain Block. Data Sheet. ADL5535. FEATURES. FUNCTIONAL BLOCK DIAGRAM. Fixed gain of 16 dB. GND
20 MHz to 1.0 GHz IF Gain Block Data Sheet ADL5535 FEATURES FUNCTIONAL BLOCK DIAGRAM Fixed gain of 16 dB GND Operation from 20 MHz to 1.0 GHz (2) Input and output internally matched to 50 Ω ADL5535 Integrated bias control circuit OIP3 BIAS 45.5 dBm at 190 MHz 45.5 dBm at 380 MHz 1 2 3
001
Noise figure RFIN GND RFOUT
08674-
3.2 dB at 190 MHz
Figure 1.
3.3 dB at 380 MHz P1dB of 18.9 dBm at 190 MHz Single 5 V power supply Low quiescent current of 97 mA MSL-1 rated SOT-89 package ESD rating of ±2 kV (Class 2) Pin-compatible with the 20 dB gain ADL5536 GENERAL DESCRIPTION
The ADL5535 is a 16 dB linear amplifier that operates at The ADL5535 is fabricated on a GaAs HBT process and has an frequencies up to 1 GHz. The device can be used in a wide ESD rating of ±2 kV (Class 2). The device is assembled in an variety of cellular, CATV, military, and instrumentation MSL-1 rated SOT-89 package that uses an exposed paddle for equipment. excellent thermal impedance. The ADL5535 provides the highest dynamic range available The ADL5535 consumes only 97 mA on a single 5 V supply and from an internally matched IF gain block. This is accomplished is fully specified for operation from −40°C to +85°C. by providing extremely low noise figures and very high OIP3 The ADL5535 is also pin-compatible with the 20 dB gain specifications simultaneously across the entire 1 GHz frequency ADL5536. Fully populated evaluation boards are available range. The ADL5535 also provides extremely flat gain and P1dB for each amplifier. over frequency, which are stable over temperature, power supply, and from device to device. The device is internal y matched to 50 Ω at the input and output, making the ADL5535 very easy to implement in a wide variety of applications. Only input/output ac coupling capacitors, power supply decoupling capacitors, and an external inductor are required for operation.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2010–2013 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Soldering Information and Recommended PCB Land Pattern ACPR Performance Error Vector Magnitude (EVM) Performance ADC Driving Application Evaluation Board Outline Dimensions Ordering Guide
