Datasheet ADL5535 (Analog Devices) - 3
Description20 MHz TO 1.0 GHz IF Gain Block
Pages / Page16 / 3 — Data Sheet. ADL5535. SPECIFICATIONS. Table 1. Parameter. Test …
File Format / SizePDF / 384 Kb
Data Sheet. ADL5535. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet ADL5535 SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
VCC = 5 V and TA = 25°C, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
OVERALL FUNCTION Frequency Range 20 1000 MHz FREQUENCY = 20 MHz Gain 16.7 dB Output 1 dB Compression Point (P1dB) 17.7 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 3 dBm per tone 41.5 dBm Second Harmonic POUT = 0 dBm −59.5 dBc Third Harmonic POUT = 0 dBm −93 dBc Noise Figure 3.0 dB FREQUENCY = 70 MHz Gain 16.5 dB vs. Frequency ±50 MHz ±0.33 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.16 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.04 dB Output 1 dB Compression Point (P1dB) 18.9 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 3 dBm per tone 43.5 dBm Second Harmonic POUT = 0 dBm −64 dBc Third Harmonic POUT = 0 dBm −93 dBc Noise Figure 3.0 dB FREQUENCY = 190 MHz Gain 15.2 16.1 17.0 dB vs. Frequency ±50 MHz ±0.06 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.17 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.04 dB Output 1 dB Compression Point (P1dB) 17.8 18.9 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 3 dBm per tone 45.5 dBm Second Harmonic POUT = 0 dBm −60.2 dBc Third Harmonic POUT = 0 dBm −84.3 dBc Noise Figure 3.2 dB FREQUENCY = 380 MHz Gain 15.0 15.8 16.5 dB vs. Frequency ±50 MHz ±0.08 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.17 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.05 dB Output 1 dB Compression Point (P1dB) 17.8 18.9 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 3 dBm per tone 45.5 dBm Second Harmonic POUT = 0 dBm −61.9 dBc Third Harmonic POUT = 0 dBm −75 dBc Noise Figure 3.3 dB FREQUENCY = 748 MHz Gain 15.2 dB vs. Frequency ±50 MHz ±0.10 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.20 dB vs. Supply Voltage 4.75 V to 5.25 V ±0.06 dB Output 1 dB Compression Point (P1dB) 18.9 dBm Output Third-Order Intercept (OIP3) Δf = 1 MHz, output power (POUT) = 3 dBm per tone 42.0 dBm Second Harmonic POUT = 0 dBm −52.6 dBc Third Harmonic POUT = 0 dBm −68 dBc Noise Figure 3.2 dB Rev. A | Page 3 of 16 Document Outline Features Functional Block Diagram General Description Table of Contents Revision History Specifications Typical Scattering Parameters (S-Parameters) Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Connections Soldering Information and Recommended PCB Land Pattern ACPR Performance Error Vector Magnitude (EVM) Performance ADC Driving Application Evaluation Board Outline Dimensions Ordering Guide
