Datasheet HMC741ST89E (Analog Devices) - 4
DescriptionInGaP HBT Active Bias MMIC Amplifier, 0.05 - 3 GHz
Pages / Page8 / 4 — HMC741ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. Output …
File Format / SizePDF / 702 Kb
HMC741ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. Output Return Loss vs. Vcc. Noise Figure vs. Temperature
HMC741ST89E InGaP HBT ACTIVE BIAS MMIC AMPLIFIER, 0.05 – 3 GHz Output Return Loss vs Vcc Noise Figure vs Temperature
HMC741ST89E
v02.0710
InGaP HBT ACTIVE BIAS MMIC AMPLIFIER, 0.05 – 3 GHz Output Return Loss vs. Vcc Noise Figure vs. Temperature
0 8 8 7 -5 4.5V 5.0V 5.5V ) 6 +25C (dB -10 +85C (dB S E 5 -40C T S R U LO -15 4 IG m N R F U E 3 s T -20 IS E O R N 2 -25 k - 1 c -30 0 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 FREQUENCY (GHz) FREQUENCY (GHz) lo in B
Noise Figure vs. Vcc Reverse Isolation vs. Temperature
A 8 0 7 ) -5 ) 6 (dB 4.5V N +25C r & G 5.0V (dB -10 IO +85C E 5 5.5V T -40C e R U LA 4 O -15 IG iv F IS E E 3 S IS r R -20 O E N V 2 E R -25 1 s - D 0 -30 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 r FREQUENCY (GHz) FREQUENCY (GHz) ie lif p
Reverse Isolation vs. Vcc Output IP3 vs. Temperature
m 0 50 A 45 ) -5 40 (dB N 4.5V 35 -10 IO 5.0V ) T 5.5V m 30 LA O -15 25 IS 3 (dB E IP 20 S +25C R -20 +85C E 15 -40C V E R 10 -25 5 -30 0 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 FREQUENCY (GHz) FREQUENCY (GHz) Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
8 - 4
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
