Datasheet HMC741ST89E (Analog Devices)
DescriptionInGaP HBT Active Bias MMIC Amplifier, 0.05 - 3 GHz
Pages / Page8 / 1 — HMC741ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. Typical …
File Format / SizePDF / 702 Kb
HMC741ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC741ST89E Analog Devices
HMC741ST89E
v02.0710
InGaP HBT ACTIVE BIAS MMIC AMPLIFIER, 0.05 – 3 GHz Typical Applications Features
8 The Hmc741sT89e is ideal for: p1dB output power: +18.5 dBm • cel ular/3G & WimAX/4G Gain: 20 dB • fixed Wireless & WlAn output ip3: +42 dBm T • cATv, cable modem & DBs cascadable 50 ohm i/os m s • microwave radio & Test equipment single supply: +5v • if & rf Applications industry standard soT89 package k - robust 1000v esD, class 1c c stable current over Temperature lo Active Bias network in B
A The Hmc741sT89e is an inGap Heterojunction Bipolar Transistor (HBT) Gain Block mmic smT amplifier covering 0.05 to 3 GHz. packaged in an industry standard soT89, the amplifier can be used r & G as a cascadable 50 ohm rf or if gain stage as well e as a pA or lo driver with up to +18.5 dBm output iv power. The Hmc741sT89e offers 20 dB of gain with r a +42 dBm output ip3 at 200 mHz, and can operate directly from a +5v supply. The Hmc741sT89e exhibits excel ent gain and output power stability over s - D temperature, while requiring a minimal number of r external bias components. ie lif p
Electrical Specifications, Vcc = 5V, T = +25° C
m
A
A parameter min. Typ. max. min. Typ. max. min. Typ. max. min. Typ. max. Units frequency range 150 240 50 - 1000 50 - 3000 mHz Gain 19 20 19 21 16 20 12 19 dB Gain flatness ±0.3 ±0.3 ±0.3 ±2.6 dB Gain variation over Temperature 0.004 0.004 0.004 0.01 0.004 0.01 dB/ °c input return loss 16 16 16 12 dB output return loss 17 17 17 12 dB reverse isolation 25 25 25 26 dB output power for 1 dB compression 16 18.8 16 18.8 16 18.8 14 16 dBm (p1dB) output Third order intercept (ip3) (pout= 0 dBm per tone, 40.5 40.5 40.5 30 dBm 1 mHz spacing) noise figure 2.5 2.5 2.5 2.5 dB supply current (icq) 96 96 96 96 mA Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m
8 - 1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
