Datasheet HMC741ST89E (Analog Devices) - 2
DescriptionInGaP HBT Active Bias MMIC Amplifier, 0.05 - 3 GHz
Pages / Page8 / 2 — HMC741ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. IF Band …
File Format / SizePDF / 702 Kb
HMC741ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. IF Band Performance. Gain & Return Loss
HMC741ST89E InGaP HBT ACTIVE BIAS MMIC AMPLIFIER, 0.05 – 3 GHz IF Band Performance Gain & Return Loss
HMC741ST89E
v02.0710
InGaP HBT ACTIVE BIAS MMIC AMPLIFIER, 0.05 – 3 GHz IF Band Performance Gain & Return Loss Gain vs. Temperature
25 30 20 8 15 25 10 ) S21 S11 5 20 S22 (dB ) T E S 0 N (dB 15 IN m O -5 P A +25C S G +85C s E -10 -40C R 10 -15 -20 5 k - -25 c -30 0 0 0.2 0.4 0.6 0.8 1 0 0.2 0.4 0.6 0.8 1 FREQUENCY (GHz) FREQUENCY (GHz) lo in B
Noise Figure vs. Temperature Output IP3 vs. Temperature
A 8 50 7 45 ) 6 +25C r & G +85C (dB 40 E 5 -40C ) e R m U 4 35 IG iv F 3 (dB E IP 3 +25C IS r 30 O +85C N -40C 2 25 1 s - D 0 20 0 0.2 0.4 0.6 0.8 1 0 0.2 0.4 0.6 0.8 1 r FREQUENCY (GHz) FREQUENCY (GHz) ie lif p
Output IP3 vs. Vcc Output IP3 vs. Output Power
50 50 m 45 A 45 40 35 40 ) m m 30 35 25 3 (dB 3 (dB IP IP 20 30 4.5V 15 100MHz 5.0V 400MHz 10 25 5.5V 1GHz 5 20 0 0 0.2 0.4 0.6 0.8 1 -5 0 5 10 15 FREQUENCY (GHz) Pout (dBm) Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
8 - 2
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
