Datasheet ADL5531 (Analog Devices) - 3
Description20 MHz TO 500 MHz IF Gain Block
Pages / Page12 / 3 — Data Sheet. ADL5531. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. …
RevisionC
File Format / SizePDF / 511 Kb
Data Sheet. ADL5531. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. Typ. Max. Unit
Data Sheet ADL5531 SPECIFICATIONS Table 1 Parameter Conditions Min Typ Max Unit
VPOS = 5 V and TA = 25°C, unless otherwise noted.
Table 1. Parameter Conditions Min Typ Max Unit
OVERALL FUNCTION Frequency Range 20 500 MHz Gain (S21) 190 MHz 20.3 dB Input Return Loss (S11) 190 MHz −19.5 dB Output Return Loss (S22) 190 MHz −26.5 dB Reverse Isolation (S12) 190 MHz −23.0 dB FREQUENCY = 70 MHz Gain 20.9 dB vs. Frequency ± 5 MHz ±0.03 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.22 dB vs. Supply 4.75 V to 5.25 V ±0.19 dB Output 1 dB Compression Point 20.4 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = 0 dBm per tone 41.0 dBm Noise Figure 2.5 dB FREQUENCY = 190 MHz Gain 19.7 20.3 21.0 dB vs. Frequency ± 50 MHz ±0.12 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.22 dB vs. Supply 4.75 V to 5.25 V ±0.17 dB Output 1 dB Compression Point 20.6 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = 0 dBm per tone 39.0 dBm Noise Figure 2.5 dB FREQUENCY = 380 MHz Gain 19.2 19.7 20.5 dB vs. Frequency ± 50 MHz ±0.15 dB vs. Temperature −40°C ≤ TA ≤ +85°C ±0.24 dB vs. Supply 4.75 V to 5.25 V ±0.15 dB Output 1 dB Compression Point 20.4 dBm Output Third-Order Intercept Δf = 1 MHz, output power (POUT) = 0 dBm per tone 36.0 dBm Noise Figure 3.0 dB POWER INTERFACE Pin RFOUT Supply Voltage 4.75 5 5.25 V Supply Current 100 110 mA vs. Temperature −40°C ≤ TA ≤ +85°C ±15 mA Power Dissipation VPOS = 5 V 0.5 W Rev. C | Page 3 of 12 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
