Data SheetADL5541PIN CONFIGURATION AND FUNCTION DESCRIPTIONSRFIN 18 RFOUTGND 27 GNDADL5541TOP VIEWGND 36 GND(Not to Scale) 002 CB 45 VPOS 06877- NOTES 1. EXPOSED PADDLE. INTERNALLY CONNECTED TO GND. SOLDER TO A LOW IMPEDANCE GROUND PLANE. Figure 2. Pin Configuration Table 4. Pin Function Descriptions Pin No.MnemonicDescription 1 RFIN RF Input. Requires a dc blocking capacitor. 2, 3, 6, 7 GND Ground. Connect these pins to a low impedance ground plane. 4 CB Low Frequency Bypass. A 1 µF capacitor should be connected between this pin and ground. 5 VPOS Power Supply for Bias Controller. Connect directly to external power supply. 8 RFOUT RF Output and Supply Voltage. DC bias is provided to this pin through an inductor that is tied to the external power supply. RF path requires a dc blocking capacitor. Exposed Paddle Exposed Paddle. Internally connected to GND. Solder to a low impedance ground plane. Rev. B | Page 7 of 13 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TYPICAL SCATTERING PARAMETERS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OPERATING TO 20 MHz BASIC CONNECTIONS SOLDERING INFORMATION AND RECOMMENDED PCB LAND PATTERN EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
