HMC480ST89 / 480ST89E v02.0710 InGaP HBT GAIN BLOCKMMIC AMPLIFIER, DC - 5 GHzTypical ApplicationsFeatures 8 The HMC480ST89 / HMC480ST89E is an ideal RF/IF P1dB Output Power: +19 dBm to 2.5 GHz gain block & LO or PA driver for: Gain: 19 dB @ 1 GHz 16 dB @ 2 GHz • Cellular / PCS / 3G T +34 dBm Output IP3 • Fixed Wireless & WLAN Single Supply: +6V to +8V • CATV, Cable Modem & DBS Industry Standard SOT89 Package • Microwave Radio & Test Equipment Included in the HMC-DK001 Designer’s Kits K - SM Functional DiagramGeneral Description OC The HMC480ST89 & HMC480ST89E are InGaP HBT BL Gain Block MMIC SMT amplifi ers covering DC to 5 GHz and packaged in an industry standard IN SOT89. The amplifi er can be used as a cascadable A 50 Ohm RF/IF gain stage as well as a LO or PA driver with up to +20 dBm P1dB output power for cellular/3G, & G FWA, CATV, microwave radio and test equipment R applications. The HMC480ST89(E) offers 19 dB E of gain with a +34 dBm output IP3 at 1 GHz while IV requiring only 82 mA from a single positive supply. R The HMC480ST89(E) InGaP gain blocks offer excellent output IP3 and fl at +19 to +20dBm output power performance through 5 GHz compared to - D equivalent SiGe based products. S R Electrical Specifi cations, Vs= 8.0 V, Rbias= 39 Ohm, T = +25° C IE A Parameter Min. Typ. Max. Units IF L DC - 1.0 GHz 17 19 dB 1.0 - 2.0 GHz 14 17 dB P Gain 2.0 - 3.0 GHz 12 15 dB M 3.0 - 4.0 GHz 10 13 dB 4.0 - 5.0 GHz 8 11 dB A Gain Variation Over Temperature DC - 5 GHz 0.008 0.016 dB/ °C DC - 1.0 GHz 17 dB Input Return Loss 1.0 - 5.0 GHz 10 dB DC - 1.0 GHz 17 dB Output Return Loss 1.0 - 5.0 GHz 10 dB Reverse Isolation DC - 5 GHz 20 dB 0.5 - 1.0 GHz 16 20 dBm 1.0 - 2.0 GHz 15.5 18.5 dBm Output Power for 1 dB Compression (P1dB) 2.0 - 3.5 GHz 14.5 17.5 dBm 3.5 - 5.0 GHz 13 16 dBm 0.5 - 1.0 GHz 34 dBm Output Third Order Intercept (IP3) 1.0 - 2.0 GHz 33 dBm (Pout= 0 dBm per tone, 1 MHz spacing) 2.0 - 3.5 GHz 32 dBm 3.5 - 5.0 GHz 30 dBm DC - 4 GHz 3.25 dB Noise Figure 4.0 - 5.0 GHz 4.0 dB Supply Current (Icq) 82 mA Note: Data taken with broadband bias tee on device output. Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m 8 - 122 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
