HMC480ST89 / 480ST89E v02.0710 InGaP HBT GAIN BLOCKMMIC AMPLIFIER, DC - 5 GHzEvaluation PCB 8 T K - SM OC BL IN A & G R E IV R - D S R IE IF L List of Materials for Evaluation PCB 108371 [1] P The circuit board used in the fi nal application Item Description M should use RF circuit design techniques. Signal J1 - J2 PCB Mount SMA Connector A lines should have 50 Ohm impedance while the J3 - J4 DC Pin package ground leads and package bottom should C1, C2 Capacitor, 0402 Pkg. be connected directly to the ground plane similar to C3 100 pF Capacitor, 0402 Pkg. that shown. A sufficient number of via holes should C4 1000 pF Capacitor, 0603 Pkg. be used to connect the top and bottom ground C5 2.2 μF Capacitor, Tantalum planes. The evaluation board should be mounted R1 Resistor, 1210 Pkg. to an appropriate heat sink. The evaluation circuit L1 Inductor, 0603 Pkg. board shown is available from Hittite upon request. U1 HMC480ST89 / HMC480ST89E PCB [2] 108370 Evaluation PCB [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350 Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com 8 - 127 Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
