Datasheet AD8354 (Analog Devices) - 5
Description1 MHz TO 2.7 GHz RF Gain Block
Pages / Page16 / 5 — Data Sheet. AD8354. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. …
RevisionF
File Format / SizePDF / 366 Kb
Data Sheet. AD8354. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. ESD CAUTION
Data Sheet AD8354 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
Data Sheet AD8354 ABSOLUTE MAXIMUM RATINGS Table 3.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Supply Voltage, VPOS 5.5 V stress rating only; functional operation of the product at these Input Power (re: 50 Ω) 10 dBm or any other conditions above those indicated in the operational Equivalent Voltage 700 mV rms section of this specification is not implied. Operation beyond Internal Power Dissipation the maximum operating conditions for extended periods may Paddle Not Soldered 325 mW affect product reliability. Paddle Soldered 812 mW θ JA (Paddle Soldered) 80°C/W θJA (Paddle Not Soldered) 200°C/W
ESD CAUTION
Maximum Junction Temperature 150°C Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering, 60 sec) AD8354ACP (Non-RoHS Compliant) 240°C AD8354ACPZ (RoHS Compliant) 260°C Rev. F | Page 5 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS APPLICATIONS INFORMATION LOW FREQUENCY APPLICATIONS BELOW 100 MHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
