AD8354Data Sheet VS = 5 V, TA = 25°C, no external inductor between VOUT and VPOS, ZO = 50 Ω, unless otherwise noted. Table 2. ParameterConditionsMinTypMaxUnit OVERALL FUNCTION Frequency Range 1 2700 MHz Gain f = 900 MHz 19.5 dB f = 1.9 GHz 18.7 dB f = 2.7 GHz 17.3 dB Delta Gain f = 900 MHz, −40°C ≤ TA ≤ +85°C −0.93 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C −0.99 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C −1.21 dB Gain Supply Sensitivity VPOS ± 10%, f = 900 MHz 0.32 dB/V f = 1.9 GHz 0.21 dB/V f = 2.7 GHz 0.08 dB/V Reverse Isolation (S12) f = 900 MHz −33.5 dB f = 1.9 GHz −37.6 dB f = 2.7 GHz −32.9 dB RF INPUT INTERFACE Pin INPT Input Return Loss f = 900 MHz 24.4 dB f = 1.9 GHz 23.9 dB f = 2.7 GHz 13.5 dB RF OUTPUT INTERFACE Pin VOUT Output Compression Point f = 900 MHz 4.8 dBm f = 1.9 GHz 4.6 dBm f = 2.7 GHz 3.6 dBm Delta Compression Point f = 900 MHz, −40°C ≤ TA ≤ +85°C 0.37 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C −0.14 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C −0.05 dB Output Return Loss f = 900 MHz 23.7 dB f = 1.9 GHz 22.5 dB f = 2.7 GHz 17.6 dB DISTORTION/NOISE Output Third-Order Intercept f = 900 MHz, ∆f = 50 MHz, PIN = −30 dBm 19.3 dBm f = 1.9 GHz, ∆f = 50 MHz, PIN = −30 dBm 17.3 dBm f = 2.7 GHz, ∆f = 50 MHz, PIN = −30 dBm 15.3 dBm Output Second-Order Intercept f = 900 MHz, ∆f = 1 MHz, PIN = −28 dBm 28.7 dBm Noise Figure f = 900 MHz 4.4 dB f = 1.9 GHz 5 dB f = 2.7 GHz 5.6 dB POWER INTERFACE Pin VPOS Supply Voltage 4.5 5 5.5 V Total Supply Current TA = 27°C 17 25 34 mA Supply Voltage Sensitivity 4 mA/V Temperature Sensitivity −40°C ≤ TA ≤ +85°C 28 µA/°C Rev. F | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS APPLICATIONS INFORMATION LOW FREQUENCY APPLICATIONS BELOW 100 MHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
