Datasheet AD8354 (Analog Devices) - 3
Description1 MHz TO 2.7 GHz RF Gain Block
Pages / Page16 / 3 — Data Sheet. AD8354. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. …
RevisionF
File Format / SizePDF / 366 Kb
Data Sheet. AD8354. SPECIFICATIONS. Table 1. Parameter. Conditions. Min. Typ. Max. Unit
Data Sheet AD8354 SPECIFICATIONS Table 1 Parameter Conditions Min Typ Max Unit
VS = 3 V, TA = 25°C, 100 nH external inductor between VOUT and VPOS, ZO = 50 Ω, unless otherwise noted.
Table 1. Parameter Conditions Min Typ Max Unit
OVERALL FUNCTION Frequency Range 1 2700 MHz Gain f = 900 MHz 19.5 dB f = 1.9 GHz 18.6 dB f = 2.7 GHz 17.1 dB Delta Gain f = 900 MHz, −40°C ≤ TA ≤ +85°C −0.97 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C −1.05 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C −1.33 dB Gain Supply Sensitivity VPOS ± 10%, f = 900 MHz 0.54 dB/V f = 1.9 GHz 0.37 dB/V f = 2.7 GHz 0.2 dB/V Reverse Isolation (S12) f = 900 MHz −33.5 dB f = 1.9 GHz −38 dB f = 2.7 GHz −32.9 dB RF INPUT INTERFACE Pin INPT Input Return Loss f = 900 MHz 24.4 dB f = 1.9 GHz 23 dB f = 2.7 GHz 12.7 dB RF OUTPUT INTERFACE Pin VOUT Output Compression Point f = 900 MHz, 1 dB compression 4.6 dBm f = 1.9 GHz 3.7 dBm f = 2.7 GHz 2.7 dBm Delta Compression Point f = 900 MHz, −40°C ≤ TA ≤ +85°C 0.7 dB f = 1.9 GHz, −40°C ≤ TA ≤ +85°C 0.7 dB f = 2.7 GHz, −40°C ≤ TA ≤ +85°C 0.8 dB Output Return Loss f = 900 MHz 23.6 dB f = 1.9 GHz 16.5 dB f = 2.7 GHz 14.6 dB DISTORTION/NOISE Output Third-Order Intercept f = 900 MHz, ∆f = 1 MHz, PIN = −28 dBm 19 dBm f = 1.9 GHz, ∆f = 1 MHz, PIN = −28 dBm 16 dBm f = 2.7 GHz, ∆f = 1 MHz, PIN = −28 dBm 14.2 dBm Output Second-Order Intercept f = 900 MHz, ∆f = 1 MHz, PIN = −28 dBm 29.7 dBm Noise Figure f = 900 MHz 4.2 dB f = 1.9 GHz 4.8 dB f = 2.7 GHz 5.4 dB POWER INTERFACE Pin VPOS Supply Voltage 2.7 3 3.3 V Total Supply Current 16 23 31 mA Supply Voltage Sensitivity 6.2 mA/V Temperature Sensitivity −40°C ≤ TA ≤ +85°C 33 µA/°C Rev. F | Page 3 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC CONNECTIONS APPLICATIONS INFORMATION LOW FREQUENCY APPLICATIONS BELOW 100 MHz EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
