Datasheet HMC313, 313E (Analog Devices)
DescriptionGaAs InGaP HBT MMIC BROADBAND AMPLIFIER GAIN BLOCK, DC - 6 GHz
Pages / Page6 / 1 — HMC313 / 313E. GaAs InGaP HBT MMIC BROADBAND. AMPLIFIER GAIN BLOCK, DC - …
File Format / SizePDF / 930 Kb
HMC313 / 313E. GaAs InGaP HBT MMIC BROADBAND. AMPLIFIER GAIN BLOCK, DC - 6 GHz. Typical Applications. Features
Datasheet HMC313, 313E Analog Devices
HMC313 / 313E
v07.0418
GaAs InGaP HBT MMIC BROADBAND AMPLIFIER GAIN BLOCK, DC - 6 GHz Typical Applications Features
Ideal as a Driver & Amplifier for: P1dB Output Power: +14 dBm T • 2.2 - 2.7 GHz MMDS Output IP3: +27 dBm M S • 3.5 GHz Wireless Local Loop Gain: 17 dB • 5 - 6 GHz UNII & HiperLAN Single Supply: +5V S - High Reliability GaAs HBT Process R Ultra Small Package: SOT26 IE Included in the HMC-DK001 Designer’s Kit LIF P M
The HMC313 & HMC313E are GaAs InGaP K A Heterojunction Bipolar Transistor (HBT) MMIC C amplifiers that operate from a single Vcc supply. The surface mount SOT26 amplifier can be used LO as a broadband gain stage or used with external matching for optimized narrow band applications. With Vcc biased at +5V, the HMC313(E) offers 17 dB IN B of gain and +15 dBm of saturated power while only A requiring 50 mA of current. G R & E IV R D
Electrical Specifications, T = +25 °C, Vcc = +5.0V A
Vcc = +5V Parameter Units Min. Typ. Max. Frequency Range DC - 6 GHz Gain 14 17 20 dB Gain Variation Over Temperature 0.02 0.03 dB/°C Input Return Loss 7 dB Output Return Loss 6 dB Reverse Isolation 30 dB Output Power for 1 dB Compression (P1dB) @ 1.0 GHz 11 14 dBm Saturated Output Power (Psat) @ 1.0 GHz 15 dBm Output Third Order Intercept (IP3) @ 1.0 GHz 24 27 dBm Noise Figure 6.5 dB Supply Current (Icc) 50 mA Note: Data taken with broadband bias tee on device output. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D
