Datasheet SM8SF-Q (Bourns) - 4
ManufacturerBourns
Description7000 W TVS Diodes - VWM 24~36 V - DFN Package - AEC-Q101 Compliant
Pages / Page6 / 4 — SM8SF-Q Transient Voltage Suppressor Diode Series. Physical …
File Format / SizePDF / 453 Kb
SM8SF-Q Transient Voltage Suppressor Diode Series. Physical Specifications. Typical Part Marking. SM8SFxxA-Q. How to Order
SM8SF-Q Transient Voltage Suppressor Diode Series Physical Specifications Typical Part Marking SM8SFxxA-Q How to Order
Case ...Molded plastic per UL Class 94V-0
SM8SFxxA-Q
Polarity... Cathode band indicates unidirectional device SERIES: No cathode band indicates bidirectional device SM8S = SM8SF A = 5 % TOLERANCE UNIDIRECTIONAL DEVICE
How to Order
SM8S
SM8SF 33 CA - Q
33A WORKING YWW PEAK Package REVERSE SM8SF = 0.41 inch x 0.32 inch size VOLTAGE 33 = 33 V Working Peak Reverse Voltage DATE CODE: 33 = 33 V Y = LAST DIGIT OF YEAR RWM (Volts) CATHODE BAND (UNIDIRECTIONAL Suffix WW = WEEK NUMBER DEVICES ONLY) A = 5 % Tolerance Unidirectional Device CA = 5 % Tolerance Bidirectional Device AEC-Q101 Suffix Q = AEC-Q101 Compliant
SM8SFxxCA-Q
SERIES: SM8S = SM8SF CA = 5 % TOLERANCE
Environmental Specifications
BIDIRECTIONAL DEVICE Moisture Sensitivity Level ..1 ESD Classification (HBM)... 3B SM8S 33CA WORKING YWW PEAK REVERSE VOLTAGE 33 = 33 V DATE CODE: Y = LAST DIGIT OF YEAR WW = WEEK NUMBER Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
