Datasheet SM8SF-Q (Bourns) - 5
ManufacturerBourns
Description7000 W TVS Diodes - VWM 24~36 V - DFN Package - AEC-Q101 Compliant
Pages / Page6 / 5 — CDDFN5-0504N. SM8SF-Q T. - TVS/Steering. ransient V. Diode Array. oltage …
File Format / SizePDF / 453 Kb
CDDFN5-0504N. SM8SF-Q T. - TVS/Steering. ransient V. Diode Array. oltage Suppressor Diode Series. Packaging Information. Item. Symbol
CDDFN5-0504N SM8SF-Q T - TVS/Steering ransient V Diode Array oltage Suppressor Diode Series Packaging Information Item Symbol
The product will be dispensed in tape and reel format (see diagram below). P0 P P 0 E T 1 d Index Hole P E T 1 d Index Hole 120 ° F 120 ° D2 W F D B 2 W D1 D B D1 D P A C P A C Trailer Device Leader Trailer Device Leader ... ... ... ... W1 End ... ... ... ... ... ... ... ... Start W1 End Start DIMENSIONS: MM ... ... ... ... (INCHES) 10 pitches (min.) 10 pitches (min.) 10 pitches (min.) 10 pitches (min.) Devices are packed in accordance with EIA 481 Direction of Feed standard specifications shown here. Direction of Feed
Item Symbol SM8SF Series
Carrier Width A 8.35 ± 0.10 (0.329 ± 0.004) Part Pick-up Carrier Length B 10.75 ± 0.10 Height (0.423 ± 0.004) Part Carrier Depth C 1.65 ± 0.10 Thickness (0.065 ± 0.004) 0.3 mm above PCB Sprocket Hole d 1.55 ± 0.05 (0.061 ± 0.002) Reel Outside Diameter D 178 ± 1.0 (7.008 ± 0.039) Reel Inner Diameter D 60 ± 1.0 1 (2.362 ± 0.039) PCB Feed Hole Diameter D 13.5 ± 0.50 2 (0.531 ± 0.02) Recommended pick-up height: The bottom of the device Sprocket Hole Position E 1.75 ± 0.10 (0.069 ± 0.004) should be 0.3 mm above the PCB. Punch Hole Position F 5.50 ± 0.10 (0.217 ± 0.004) Punch Hole Pitch P 12.00 ± 0.10 (0.472 ± 0.004) Sprocket Hole Pitch P 4.00 ± 0.10 0 (0.157 ± 0.004) Embossment Center P 2.00 ± 0.10 1 (0.079 ± 0.004) Overall Tape Thickness T 0.40 (0.016) MAX. Tape Width W 16.00 ± 0.30 (0.630 ± 0.012) Reel Width W 18.1 ± 1.2 1 (0.713 ± 0.047) Quantity per Reel -- 750 02/19 Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
