Datasheet BZX84 (Nexperia) - 4
Manufacturer | Nexperia |
Description | Voltage regulator diodes |
Pages / Page | 16 / 4 — Nexperia. BZX84 series. Voltage regulator diodes. 5. Limiting. values. … |
Revision | 07082018 |
File Format / Size | PDF / 1.0 Mb |
Nexperia. BZX84 series. Voltage regulator diodes. 5. Limiting. values. Table 5. Limiting values. Symbol. Parameter. Conditions. Min. Max. Unit
- BZX84-A10,215 BZX84-A11,215 BZX84-A12,215 BZX84-A13,215 BZX84-A15,215 BZX84-A16,215 BZX84-A20,215 BZX84-A22,215 BZX84-A22,235 BZX84-A24,215 BZX84-A27,215 BZX84-A2V4,215 BZX84-A2V4,235 BZX84-A2V7,215 BZX84-A30,215 BZX84-A33,215 BZX84-A36,215 BZX84-A39,215 BZX84-A3V0,215 BZX84-A3V3,215 BZX84-A3V6,215 BZX84-A3V9,215 BZX84-A43,215 BZX84-A4V3,215 BZX84-A4V7,215 BZX84-A51,215 BZX84-A5V1,215 BZX84-A5V1,235 BZX84-A5V6,215 BZX84-A6V2,215 BZX84-A6V8,215 BZX84-A75,215 BZX84-A7V5,215 BZX84-A8V2,215 BZX84-A9V1,215 BZX84-B10,215 BZX84-B10,235 BZX84-B11,215 BZX84-B11,235 BZX84-B12,215 BZX84-B13,215 BZX84-B13,235 BZX84-B15,215 BZX84-B15,235 BZX84-B16,215 BZX84-B18,215 BZX84-B18,235 BZX84-B20,215 BZX84-B20,235 BZX84-B22,215 BZX84-B22,235 BZX84-B24,215 BZX84-B27,215 BZX84-B27,235 BZX84-B2V4,215 BZX84-B2V7,215 BZX84-B30,215 BZX84-B33,215 BZX84-B36,215 BZX84-B39,215 BZX84-B3V0,215 BZX84-B3V0,235 BZX84-B3V3,215 BZX84-B3V6,215 BZX84-B3V6VL BZX84-B3V9,215 BZX84-B43,215 BZX84-B47,215 BZX84-B4V3,215 BZX84-B4V3,235 BZX84-B4V7,215 BZX84-B51,215 BZX84-B56,215 BZX84-B5V1,215 BZX84-B5V1,235 BZX84-B5V6,215 BZX84-B5V6,235 BZX84-B62,215 BZX84-B68,215 BZX84-B6V2,215 BZX84-B6V8,215 BZX84-B75,215 BZX84-B7V5,215 BZX84-B7V5,235 BZX84-B8V2,215 BZX84-B8V2,235 BZX84-B9V1,215 BZX84-C10,215 BZX84-C10,235 BZX84-C11,215 BZX84-C11,235 BZX84-C12,215 BZX84-C12,235 BZX84-C13,215 BZX84-C13,235 BZX84-C15,215 BZX84-C15,235 BZX84-C15/CH,235 BZX84-C15/DG,215 BZX84-C16,215 BZX84-C16,235 BZX84-C18,215 BZX84-C18,235 BZX84-C20,215 BZX84-C20,235 BZX84-C22,215 BZX84-C22,235 BZX84-C24,215 BZX84-C24,235 BZX84-C27,215 BZX84-C27,235 BZX84-C2V4,215 BZX84-C2V4,235 BZX84-C2V7,215 BZX84-C2V7,235 BZX84-C30,215 BZX84-C30,235 BZX84-C33,215 BZX84-C33,235 BZX84-C36,215 BZX84-C36,235 BZX84-C39,215 BZX84-C39,235 BZX84-C3V0,215 BZX84-C3V0,235 BZX84-C3V3,215 BZX84-C3V3,235 BZX84-C3V6,215 BZX84-C3V6,235 BZX84-C3V9,215 BZX84-C3V9,235 BZX84-C43,215 BZX84-C47,215 BZX84-C47,235 BZX84-C4V3,215 BZX84-C4V3,235 BZX84-C4V7,215 BZX84-C4V7,235 BZX84-C51,215 BZX84-C51,235 BZX84-C56,215 BZX84-C5V1,215 BZX84-C5V1,235 BZX84-C5V1/DG,215 BZX84-C5V6,215 BZX84-C5V6,235 BZX84-C5V6/CH,235 BZX84-C5V6/DG,215 BZX84-C62,215 BZX84-C62,235 BZX84-C68,215 BZX84-C68,235 BZX84-C6V2,215 BZX84-C6V2,235 BZX84-C6V8,215 BZX84-C6V8,235 BZX84-C75,215 BZX84-C75,235 BZX84-C7V5,215 BZX84-C7V5,235 BZX84-C8V2,215 BZX84-C8V2,235 BZX84-C9V1,215 BZX84-C9V1,235
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
Nexperia BZX84 series Voltage regulator diodes 5. Limiting values Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter Conditions Min Max Unit
IF forward current - 200 mA P [1] ZSM non-repetitive peak - 40 W reverse power dissipation P tot total power dissipation Tamb 25 C [2] - 250 mW Tamb ambient temperature - 150 C Tstg storage temperature 55 +150 C Tj junction temperature 65 +150 C [1] tp = 100 s; square wave; Tj = 25 C before surge [2] Device mounted on a FR4 PCB, single-sided copper, tin-plated and standard footprint.
6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit
Rth(j-a) thermal resistance from in free air [1] - - 500 K/W junction to ambient R [2] th(j-sp) thermal resistance from - - 330 K/W junction to solder point [1] Device mounted on a FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Soldering point of cathode tab.
7. Characteristics Table 7. Characteristics
Tj = 25 C unless otherwise specified.
VF forward voltage IF = 10 mA [1] - - 0.9 V [1] Pulse test: t p 100 s; 0.02 BZX84_SER All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2017. All rights reserved
Product data sheet Rev. 6 — 6 March 2014 4 of 16
Document Outline 1. Product profile 1.1 General description 1.2 Features and benefits 1.3 Applications 1.4 Quick reference data 2. Pinning information 3. Ordering information 4. Marking 5. Limiting values 6. Thermal characteristics 7. Characteristics 8. Test information 8.1 Quality information 9. Package outline 10. Packing information 11. Soldering 12. Revision history 13. Legal information 13.1 Data sheet status 13.2 Definitions 13.3 Disclaimers 13.4 Trademarks 14. Contact information 15. Contents
