Datasheet S-35710 (ABLIC) - 2
Manufacturer | ABLIC |
Description | Programmable Wake-up Timer IC |
Pages / Page | 32 / 2 — WAKE-UP TIMER IC PROGRAMMABLE WAKE-UP TIMER IC. S-35710 Series. Block … |
Revision | 1.0_00 |
File Format / Size | PDF / 795 Kb |
WAKE-UP TIMER IC PROGRAMMABLE WAKE-UP TIMER IC. S-35710 Series. Block Diagram. Figure 1
WAKE-UP TIMER IC PROGRAMMABLE WAKE-UP TIMER IC S-35710 Series
Rev.1.0_00
Block Diagram
Pull-up RST Chattering elimination XIN Oscillation circuit circuit XOUT Internal reset signal Divider, INT pin T iming generator controller INT Wake-up time register Comparator Timer (24- bit) Power-on VDD detection Time register circuit Constant SDA voltage circuit Serial interface VSS SCL
Figure 1
2
