Datasheet S-35710 (ABLIC) - 8
ManufacturerABLIC
DescriptionProgrammable Wake-up Timer IC
Pages / Page32 / 8 — WAKE-UP TIMER IC PROGRAMMABLE WAKE-UP TIMER IC. S-35710 Series. DC …
Revision1.0_00
File Format / SizePDF / 795 Kb
WAKE-UP TIMER IC PROGRAMMABLE WAKE-UP TIMER IC. S-35710 Series. DC Electrical Characteristics. Table 7. *1. *2. *3. *4
WAKE-UP TIMER IC PROGRAMMABLE WAKE-UP TIMER IC S-35710 Series DC Electrical Characteristics Table 7 *1 *2 *3 *4
Rev.1.0_00
(Ta = −40°C to +85°C, VSS = 0 V unless otherwise specified) (Quartz crystal (NX3215SD, CL = 6.0 pF / 9.0 pF) manufactured by Nihon Dempa Kogyo Co., Ltd.) Item Symbol Applied Pin Condition Min. Typ. Max. Unit VDD = 3.0 V, Out of communication, _______ RST pin = V DD, − 0.2 0.35 μA INT pin = no load, Current C I L = 6.0 pF consumption 1 DD1 − VDD = 3.0 V, Out of communication, _______ RST pin = V DD, − 0.26 0.5 μA INT pin = no load, CL = 9.0 pF VDD = 3.0 V, f Current SCL = 1 MHz, I During communication, − 170 300 μA consumption 2 DD2 − _______ RST pin = V DD, INT pin = no load High level input _______ I V leakage current IZH SDA, SCL, RST IN = VDD −0.5 − 0.5 μA Low level input _______ I
*1
V leakage current IZL SDA, SCL, RST IN = VSS −0.5 − 0.5 μA High level output I leakage current OZH SDA, INT
*2
VOUT = VDD −0.5 − 0.5 μA Low level output I leakage current OZL SDA, INT
*2
VOUT = VSS −0.5 − 0.5 μA High level input _______ V − 0.7 × V voltage IH SDA, SCL, RST DD − VSS + 5.5 V Low level input _______ V − V voltage IL SDA, SCL, RST SS − 0.3 − 0.3 × VDD V High level output V voltage
*3
OH INT IOH = −0.4 mA 0.8 × VDD − − V Low level output V voltage OL SDA, INT IOL = 2.0 mA − − 0.4 V Low level input _______ I V current
*4
IL RST DD = 3.0 V, VIN = VSS −100 −30 −5 μA
*1.
S-35710C01I (without pull-up resistor)
*2.
S-35710C01I (Nch open-drain output)
*3.
S-35710B01I (CMOS output)
*4.
S-35710B01I (with pull-up resistor) 8
