Datasheet S-35720 (ABLIC) - 2
Manufacturer | ABLIC |
Description | Pin-selectable Wake-up Timer IC |
Pages / Page | 20 / 2 — WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC S-35720 Series. Block … |
Revision | 1.0_00 |
File Format / Size | PDF / 414 Kb |
WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC S-35720 Series. Block Diagram. Figure 1
Rev.1.0_00
Block Diagram
Pull-up RST Chattering elimination XIN Oscillation circuit Internal reset signal circuit XOUT Divider, INT pin Timing generator controller INT Power-on Timer (24-bit) VDD detection circuit Constant Comparator voltage SET0 circuit Interrupt time setting registor SET1 VSS
Figure 1
2
