Datasheet S-35720 (ABLIC) - 3
ManufacturerABLIC
DescriptionPin-selectable Wake-up Timer IC
Pages / Page20 / 3 — WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC. S-35720 Series. Product …
Revision1.0_00
File Format / SizePDF / 414 Kb
WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC. S-35720 Series. Product Name Structure. 1. Product name
WAKE-UP TIMER IC PIN-SELECTABLE WAKE-UP TIMER IC S-35720 Series Product Name Structure 1 Product name
Rev.1.0_00
S-35720 Series Product Name Structure 1. Product name S-35720 C xx I - K8T2 U
Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specification
*1
K8T2: TMSOP-8, Tape Operation temperature I: Ta = −40°C to +85°C Option code 01, 02 Fixed value C: Quartz crystal CL = 6.0 pF Product name
*1.
Refer to the tape drawing.
2. Package Table 1 Package Drawing Codes
Package Name Dimension Tape Reel TMSOP-8 FM008-A-P-SD FM008-A-C-SD FM008-A-R-SD
3. Product name list Table 2
_______ INT Pin SET0 Pin, SET1 Pin Settings (SET0, SET1) Product Name RST Pin Time-out Type Output Form 0, 0 0, 1 1, 0 1, 1 With pull-up Nch open-drain One-shot loop time-out S-35720C01I-K8T2U 60 s 10 s 30 s 1 s resistor output (7.8 ms
*1
) With pull-up One-shot loop time-out S-35720C02I-K8T2U CMOS output 60 s 10 s 30 s 1 s resistor (125 ms
*1
*1.
Values of pulse width. Refer to "
INT Pin Interrupt Signal Output
" for the details. 3
