Datasheet XF (IDT) - 6
Manufacturer | IDT |
Description | 150fs Small Package Quartz-based PLL Oscillator |
Pages / Page | 17 / 6 — Table 12. CML DC Electrical Characteristics. Symbol. Parameter. … |
Revision | 20190403 |
File Format / Size | PDF / 385 Kb |
Table 12. CML DC Electrical Characteristics. Symbol. Parameter. Conditions. Minimum. Typical. Maximum. Units
XF Datasheet
VDD = 3.3V, 2.5V, 1.8V ±5%, TA = -40°C to +85°C, -40°C to +105°C, typical at 156.25MHz.
Symbol Parameter Conditions Minimum Typical Maximum Units
VDD = 3.3V ±5%. 3.09 3.26 3.43 VOH Output High Voltage V V DD = 2.5V ±5%. 2.33 2.46 2.59 VDD = 1.8V ±5%. 1.66 1.76 1.85 VDD = 3.3V ±5%. 2.70 2.85 3.00 VOL Output Low Voltage V V DD = 2.5V ±5%. 1.95 2.06 2.17 VDD = 1.8V ±5%. 1.30 1.37 1.45
Table 13. DC Electrical Characteristics – Leakage Current
Symbol Parameter Input Conditions Minimum Typical Maximum Units
OE -5 0.81 5 IIH Input Leakage High SCLK VDD = 3.3V ±5%. -5 1.36 5 µA SDATA -5 1.44 5 OE -20 -17.44 -14 IIL Input Leakage Low SCLK VDD = 3.3V ±5%. -37 -33.49 -30 µA SDATA -20 -17.02 -14
AC Electrical Characteristics
Notes for al AC Electrical Characteristics tables: 1. A pull-up resistor from VDD to OE enables output when pin 1 is left open. 2. Installation should include a 0.01μF bypass capacitor placed between VDD and GND to minimize power supply line noise.
Table 14. 3.3V AC Electrical Characteristics
VDD = 3.3V ±5%, TA = -40°C to +85°C, -40°C to +105°C.
Symbol Parameter Test Condition Minimum Typical Maximum Units
LVDS, LVPECL, CML. 15 — 2100 F Output Frequency Range MHz HCSL. 15 — 725 Temperature = -40°C to +85°C. — — ±25 ppm Frequency Stability Temperature = -40°C to +105°C. — — ±50 ppm Frequency Tolerance (25°C) Temperature = 25°C. -15 ±10 -15 ppm Aging (1st year) TA = 25°C. — — ±3 ppm Aging (10 years) TA = 25°C. — — ±10 ppm ©2019 Integrated Device Technology, Inc. 6 April 3, 2019 Document Outline Description Pin Assignments Features Typical Applications Table 1. Pin Descriptions Absolute Maximum Ratings Table 2. Absolute Maximum Ratings ESD Compliance Table 3. ESD Compliance Mechanical Testing Table 4. Mechanical Testing * Solder Reflow Profile DC Electrical Characteristics Table 5. 3.3V IDD DC Electrical Characteristics Table 6. 2.5V IDD DC Electrical Characteristics Table 7. 1.8V IDD DC Electrical Characteristics Table 8. LVCMOS DC Electrical Characteristics Table 9. LVDS DC Electrical Characteristics Table 10. LVPECL DC Electrical Characteristics Table 11. HCSL DC Electrical Characteristics Table 12. CML DC Electrical Characteristics Table 13. DC Electrical Characteristics – Leakage Current AC Electrical Characteristics Table 14. 3.3V AC Electrical Characteristics Table 15. 2.5V AC Electrical Characteristics Table 16. 1.8V AC Electrical Characteristics Table 17. Phase Jitter Characteristics Output Waveforms Figure 1. LVDS Output Waveforms Figure 2. LVPECL Output Waveforms Figure 3. HCSL Output Waveforms Figure 4. CML Output Waveforms Termination for 3.3V LVPECL Outputs Figure 5. 3.3V LVPECL Output Termination Figure 6. 3.3V LVPECL Output Termination Termination for 2.5V LVPECL Outputs Figure 7. 2.5V LVPECL Driver Termination Example Figure 8. 2.5V LVPECL Driver Termination Example Figure 9. 2.5V LVPECL Driver Termination Example LVDS Driver Termination Figure 10. Standard LVDS Termination Figure 11. Optional LVDS Termination Recommended Termination for HCSL Outputs Figure 12. Recommended Source Termination (where the driver and receiver will be on separate PCBs) Figure 13. Recommended Termination (where a point-to-point connection can be used) CML Termination Figure 14. CML Termination Example Package Outline Drawings Marking Diagram Ordering Information Revision History
